View Full Version : Hobart Plasma Cutter
jtwoods4
01-26-2015, 05:53 PM
Guys, I need to cut some sections on my 70 firebird frame in order to install the speed tech chicane coil over setup. I will probably use this plasma cutter once or twice a year. Do you think it will be sufficient for cutting a 2nd gen frame?
http://www.amazon.com/gp/aw/d/B000R8UN6G?vs=1
jtwoods4
01-27-2015, 03:24 PM
Does anybody have any experience with this plasma cutter?
Spork82
01-27-2015, 05:43 PM
I've never tried the Hobart but I have an Eastwood which is very similar in that hobby range and it's been great. 2 1/2 years and no problems. Still have the same tip on it.
jtwoods4
01-27-2015, 05:47 PM
Is it powerful enough to cut the frame?
fun2run
01-27-2015, 05:51 PM
Hypertherm 30 or Thermal Dynamics. Can't go wrong with either one as the experts will tell you. I have the Hypertherm 30 and it will cut the frame as well as the others you listed. You may have to make more than one pass and it won't be clean but it will do it.
jtwoods4
01-28-2015, 09:54 AM
Fun2run if you have to make more than one pass and the cut is not clean I would say that cutter is not suited for the job. Sounds like the hypertherm 30 you reccomended is a little under powered for frame work.
Spork82
01-28-2015, 10:39 AM
I've cut 3/8 steel with mine and going slow and with the right air pressure it cuts nice. Most of the stuff I used it for is sheet metal to 1/8 plate.
jtwoods4
01-28-2015, 10:43 AM
how thick are the frames on our old muscle cars?
xavier296
01-29-2015, 08:02 AM
Not very thick. 1/8". Most any plasma cutter would work at a very slow speed. I watched the guy at the Miller booth cut 5/8" steel with the extreme 375. Thats when I knew I didn't need their bigger one.
BTW. It is like writing with a pencil it cuts so nice. It also means you need a very steady hand.
jtwoods4
01-29-2015, 08:08 AM
Awesome. Thank you.
g-machine
09-20-2015, 05:06 PM
Did you do this mod yet? I am in process of doing the same, but I am not sure about the plasma purchase.
jtwoods4
09-20-2015, 05:14 PM
yes here's a video of the mod. The plasma cutter is perfect it is very powerful and works great on everything I have done.
Cutting Video
https://youtu.be/3pXyqocdJgY
Welding Video
https://youtu.be/7GVrNSsDLw4
