View Full Version : 67 camaro with adjustable coilovers looking to go lower. options??
CamaroLS6SS
01-26-2015, 06:08 AM
I have a 67 camaro ss with adjustable coilovers all around. I have them set as low as they go and im about 3/4 of an inch away from the stance I really want. What would be my next move from here? Do I put drop spindles up front or just leave it as is. Is it worth the trouble and am I looking at complications? I`m running a 20x8.5 front wheel. Any advice would be appreciated. Thanks in advance.
dhutton
01-26-2015, 06:28 AM
Post up some pics. What lower control arms are you running? Some have a dropped pocket to allow a lower ride height. 2 inch drop spindles are generally bad news, there is a sticky about them on this forum if I remember right.
The ATS spindles have a 3/4" drop built in if I remember right and they have corrected geometry.
Don
rchaskin
01-26-2015, 06:38 AM
Could you use lighter springs?
CamaroLS6SS
01-26-2015, 07:35 AM
I`m still running the stock lower control arms. I`ll try and find a couple of pics to post.
dhutton
01-26-2015, 07:48 AM
Make sure your shock is roughly centered in its travel at your final ride height. That is why I was suggesting a lower control arm with a dropped pocket, you can still have the shock centered at a lower ride height.
How far from the bump stop are you now?
Don
CamaroLS6SS
01-26-2015, 07:59 AM
Yes a set of lower control arms would probably do the trick. I`ll look at it this afternoon. I don`t know how close it is to the bump stop right now actually I`ll have to check it out.
