hemidart67
01-24-2015, 01:57 PM
Up for sale is a complete DSE front suspension kit 3 with Wilwood big brakes on a southern 69 Camaro subframe.Im not sure on the exact size of the wilwood brakes but i can find out.
I am posting this for a friend so i can also get you his number and you can contact him for further details
He is asking $4500 Cad plus shipping
The DSE kit alone is priced at $3627 US
The only reason he is selling it is he went with the complete hydroformed subframe
This has 0 miles on it and set up for Ls1 or sbc
It is located in Ontario Canada
SPEED KIT 3
• Tubular Upper Control Arms
• Tubular Lower Control Arms- Coilover Spring Pocket
• Coilover Conversion Kit
• DSE/JRi Aluminum body coilover shocks with 'Detroit Tuned' valving
• Coilover Springs
• Front Anti-Roll bar
• DSE 600 Steering Gear With Rag Joint and Pitman Arm
• DSE Tie Rod Adjusters
• Inner and Outer Tie Rod Ends With Idler Arm
Wilwood part #140-9803-D
6-Piston Front Kit
12.88-in Rotor Diameter
1.1-in Rotor Width
17-in Min Wheel Dia*
Radial Mount Type
Fitment:GM
SPEED KIT 3
• Coilover Springs
6-Piston Front Kit
1.1-in Rotor Width
Radial Mount Type
Fitment:GM
