vette427-sbc
01-18-2015, 08:37 PM
Im getting ready to place an order for the 16 rod ends for my C4 rear suspension... I did a bit of research and so far Ive settled on the FK RSMX series with the PTFE lining. The body is alloy steel, heat treated, zinc plated chromate treated. They are rated for 40,000lbs radial load with a .625" or .5" bore and 3/4"-16 thread. I plan on using 6061 aluminum hex tubing in either 1" or 1.25" OD.
My 4 forward trailing links are in single shear at the spindle (stock vette design) and .625" bolt. The frame brackets will be double shear with a .625" bolt.
The lower camber rod has a .625" double shear bolt at the spindle and a .5" bolt on the diff. Was thinking of using the same rod ends here.
Not sure what size to use for the toe control rods. I assume I dont have to go too crazy here with load ratings? .5" bolt with 5/8-18 thread is probably more than adequate?
I know this is somewhat vague but does this sound ok? Different rod ends recommendations? How does aluminum tubing handle misalignment?
