View Full Version : 15/16" bore manual master too much for power C5 brakes
yody
10-11-2005, 06:34 PM
Finally got front C5 brakes and LT1 rear brakes on a 68 firebird that I am working on. It came with a 15/16" bore manual master cylinder, he is using a powerbooster. I modified the pushrod to be longer since the stock one was too short. Took awhile to get the brakes 100% bled but now there is no air coming out. The pedal still wants to go 3/4 of the way down to the floor, however the brakes work good. THe pedal is super sensitive and very hard to modulate. I am thinking that the size of the bore is too small and creating a low sensitive pedal. 1" bore seems to be pretty popular and works good on my car, however will a 1/16" differnece in bore size make that much of a noticable difference? thanks
chicane67
10-11-2005, 06:51 PM
Well, I have the ID of a C5 cylinder at 1.36".
A 1.0" or 1.125" would be acceptable considering that your pedal is too sensitive and that its not moving enough fluid.... shown by the 3/4 pedal travel. Noticable difference..... ??..... yup. The sensitivity and pedal travel should equalize with a diameter change.
I myself would lean towards the disc/disc 1978 WS6 master cylinder (1.125").
yody
10-11-2005, 06:55 PM
hmmm, on my car I have an LS1 cylinder, I was always told it was a 1" master?? maybe its not?
chicane67
10-11-2005, 07:26 PM
An LS1 cylinder off of what ??
yody
10-11-2005, 07:27 PM
off of an 98-02 firebird with LS1
chicane67
10-11-2005, 08:21 PM
Its probably correct..... the number I am looking at is for a Y-body and they have a different assist unit.
But the above still stands for the sizing recommendation.
yody
10-11-2005, 08:24 PM
any cast iron master you could recommend? don't want to mess with the fittings.
chicane67
10-11-2005, 08:49 PM
Ok, here ya go
Noel67
10-12-2005, 05:59 AM
Yody,
I recommend that the 1" be used in the power mode. I have a 1" Corvette master that I can send Fernando if you guys want it. The 15/16" master works very well in the manual mode. Excellent modulation and the pedal effort is only slightly more than a boosted system. It does have a hint of sponge, but that is one of the trade offs for running a manual system. I'm running our hybrid and rear disc system on my daily driven 67 with the 15/16" in the manual mode. I have 25,000 miles on my brakes now and I wouldn't have it any other way. I wish you would have at least tried the system in the manual mode, I think you would have been surprised. Either way, I will call you Fernando today and arrange for the shipment of the 1" master.
During our development, both Jonathan and I logged several thousand miles each using the 1" and 15/16" master cylinders and then decided that the 15/16" was the ticket for manual. We never tested a power sytem since neither of our cars have enough vacuum.
My hydraulics catalog has the LS1 master listed as a 1" bore.
I didn't realize I was talking to the famous Yody this weekend. It was good talking to you. Very nice car by the way.
Noel Garcia
www.touring-classics.com
70 LS1
10-15-2005, 07:06 AM
I am pretty sure the C5 master is closer to 3/4" than 1". I tried using a 1" old school corvette master with my C5 brakes and they sucked. Worse than stock performance. I swapped in a C5 master and the brakes are much better than stock. I also compared the two next to each other and the C5 is quite a bit smaller than the 1" master.
yody
10-15-2005, 08:56 AM
no way corvette is 3/4". Also thanks for trying but none of that will really help as you are just guessing.:) Can you explain how your brakes "sucked"?
70 LS1
10-15-2005, 09:47 AM
Sure. The pedal was extremely firm and difficult to push. The C5 brakes have a smaller piston in the caliper than the old C3 brakes. This causes you to push harder on the pedal to get the same clamping force on the rotors. I know for a fact I was using a 1" master, before. After talking with some C5 racers I got dimensions for the C5 master from 3/4 to 7/8 and determined that the C5 master would be the way to go. It does indeed have a smaller bore than the 1" corvette master I was using. It may be 7/8" vice 3/4", but either way it is smaller. The smaller bore creates a higher line pressure for a given pedal force. The higher line pressure in the C5 allows for better performance from smaller, lighter calipers.
Another thing you can do to adjust the sensitivity of your pedal is to alter the pedal ratio. By lowering the attachment point on the pedal you can lower the leverage assist built into it.
70 LS1
10-15-2005, 10:19 AM
OK, just measured my C5 master and it is between 13/16 and 7/8", probably metric so it didn't come out exact.
yody
10-15-2005, 10:39 AM
hmmm, I always thought you had to take out the piston to measure the correct bore? much better btw!! he already had his attachment in the lower hole
70 LS1
10-15-2005, 11:04 AM
Think of it this way. The piston has to slide in from the rear, so it can't be any larger than the opening. The opening is 13/16-7/8". The bore is the diameter of the hole drilled through the master and the piston has to be within pretty close tolerances to ensure no leaks, even with seals. Don't forget you are putting over 1000 psi on the other side of that piston.
yody
10-15-2005, 11:06 AM
yeah thats true, i guess its only the snap ring that holds it in, interesting. But then why would a 15/16 cylinder be so mushy
70 LS1
10-15-2005, 12:14 PM
Could be the pedal ratio or maybe the power booster is giving too much assist. What are you using for a booster?
427v8
10-16-2005, 08:36 AM
Pedal ratio wiould make a big difference too.
