View Full Version : Sheet Metal door Panel
DreamRyder1963
01-12-2015, 01:01 PM
I am going to need to make some custom door panels in a 95 BMW 318ti that I am selling to a friend of my brother. Normally I'm not a big fan of selling to friends but this is going to be his first car and he has fallen in love with it. I am thinking of going for hot rod / tuner look with a plain simple looking panel. Has anyone driven a car with a similar setup? I am concerned with it making the interior sound like a metal can.
Motorcitydak
01-12-2015, 01:04 PM
I was thinking of doing the same to my car and had the same concern. My thoughts were to glue a piece of thin foam cushion material to the back side of the panel. I did something similar with a switch panel I made years ago, I hated the way it sounded if you flipped a switch or touched it so I used some of that spray foam in a can to make it sound and feel more solid, for sure worked
edit:also I would be sure to use nutserts to hold it panel on, or rivets, just not sheet metal screws. Those will probably vibrate out or at least loosen over time
DreamRyder1963
01-12-2015, 02:10 PM
That was my thought that some sort of liner would take care of most of the noise but I wanted to see what others thought.
Schwartz Performance
01-12-2015, 02:44 PM
Put a sheet of Dynamat behind it before you final mount it, then it won't sound like a tin can.
-Dale
