View Full Version : Factory Emergency Brake setup to Wilwood brake
tonyvol
12-26-2014, 07:20 AM
Hey guys, I know guys have used the Lokar setup to hook to the Wilwood emergency brake on a 1st gen. Camaro.
http://www.camaros.net/forums/showthread.php?t=204983&highlight=Lokar+emergency+brakehttp://www.camaros.net/forums/showthread.php?t=204983&highlight=wilwood+emergency+brake
But I was wondering if anyone has used a factory setup to hook the emergency brakes up using Wilwoods. I would like to have a factory look if possible. I was thinking I could have someone like Control Cable make up the two cables that come off the rear brakes installed with the Lokar Explorer style clevis.(see below).
http://www.jegs.com/i/Lokar/625/EC-80CC/10002/-1
another69
12-26-2014, 09:18 AM
I used the Lokar cables hooked to the Wilwood internal drum and stock Camaro Pedal. I was never happy with it until I fabbed up some brackets that allow more leverage at the internal drum. Pretty easy to do, I made mine out of 3/16" plate. I realize that this does not answer your question, just wanted to give you a heads up in case you ran into the same issue
tonyvol
12-29-2014, 03:37 PM
Thanks Another69 for the heads.
icemanrd19
12-29-2014, 06:26 PM
Look at my thread. I used a 95 corvette rear ebrake cable
MuscleRodz
12-30-2014, 01:55 PM
You can use the Baer e brake cables I fairly certain
Chad-1stGen
12-31-2014, 01:27 PM
Have you asked Wilwood? I'm curious about this as well.
icemanrd19
12-31-2014, 09:59 PM
Parking brake assembly is installed. I wanted to use the most factory parts that i could so i bought a stock parking brake cable kit to use with my c6 brakes. The two rear cables would have been a pain to attach plus they were little long. I managed to open up the hole on the rear brake cable mount to 9/16 and i ordered 1988-1996 corvette rear ebrake cables from oriellys for $20 each using ac delco part number 19143753. These cables are much shorter and fit perfect with my brake kit and quadra link. I will attach pictures but they are not of my car since the car isn't high enough to get pictures. I then used the front cable of my kit and hooked it up to the brake and ran the line thru the subframe. Now here is where i had another problem. The intermediate cable was too short. The correct non big block cable that comes with my car from the factory is 79" long. i need about 3 more inches. Luckily firewheel classics also makes another cable part number pbk-11r for the big block camaro that is 82" long. This will work perfect.. Long store short you want the following :
1988-1995 corvette rear ebrake cables ac delco part number 19143763
67 camaro big block intermediate cable pbk-11r
front cable pbk-10a
Drill out the kore 3 bracket to 9/16"
https://static1.pt-content.com/images/pt/2014/12/rearebrake3-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/rearebrake3.jpg.html)
https://static1.pt-content.com/images/pt/2014/12/rearebrake2-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/rearebrake2.jpg.html)
icemanrd19
12-31-2014, 10:01 PM
Installed on my car
Rear 95 corvette e-brake cables
https://static1.pt-content.com/images/pt/2014/12/10881722_10100500118934926_4550324786565-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/10881722_10100500118934926_4550324786565953319_n.j pg.html)
https://static1.pt-content.com/images/pt/2014/12/10891599_10100500118825146_3562905055498-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/10891599_10100500118825146_3562905055498759168_n.j pg.html)
https://static1.pt-content.com/images/pt/2014/12/10409130_10100500118880036_1207934767329-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/10409130_10100500118880036_1207934767329699460_n.j pg.html)
tonyvol
01-01-2015, 07:37 AM
Looks like it's factory. Very nice setup. I ordered the cables from orielly's yesterday.
Smoker03
01-04-2015, 04:15 PM
Does that work with wildwood rear? Those are corvette rear brakes in the pics
tonyvol
01-04-2015, 05:55 PM
I have Wilwoods which are set up for a Ford Explorer clevis. I ordered the 95 corvette e-brake cables hoping that these would work but it looks like you will need to remove too much metal from the clevis to make it work. I think once you remove the material from the clevis it will be to weak. Maybe someone else could chime in that has gotten something to work.
I wish these would work since what Icemanrd19 has done looks killer.
willt
09-10-2019, 04:38 PM
front cable pbk-10a
Thanks for the great write up on this. As the post was back in 2011 I was wondering if anything had changed? I also see you ran the front cable through the subframe. Can I assume you do not have subframe connectors? Thanks, Will
