View Full Version : Deeper Nova front inner fenders
ford396
12-25-2014, 04:06 PM
Other than the pricey Anvil inner fenders (very nice, but out of my price range), does anyone produce a stamped steel or inexpensive fiberglass inner fender that is both wider and taller to fit my 71 Ventura. Or am I stuck with modifying mine?
Thank you
Bob
6wRacn
01-06-2015, 07:00 PM
times 2....
cornfedbill
01-07-2015, 08:51 AM
I think you are stuck. I've never seen an inexpensive wider or taller inner fender. Let me know if you find anything.
I have fiberglass inner fenders that I will be modifying for my Nova.
ford396
01-08-2015, 05:40 AM
Just finished cutting mine up and widening them out. Done. It was a job, but now that it is complete, well worth it. :)
Bob
rchaskin
01-08-2015, 05:46 AM
Bob
Cool.
Lets see some pics of it!!!
Bad94
01-09-2015, 05:26 AM
Why do you need wider ones?
I have run a 18x10 with 275 on stock sub frame and stock inner fender.
6wRacn
01-09-2015, 12:57 PM
my 70 nova is on a ridetech level 2 air suspension kit and want to be able to drop it w that wide of a front combo (have tru turn otw)....just not onto the fender! lol
ford396
01-09-2015, 06:52 PM
Just no way to get the car low enough and still turn at least 20 degrees each way otherwise. I have modified the outer lip and have the tire right out to the edge. Cannot go out any further. My 26" tire fills the inner well. Have the tire right to the rear of the inner and I still had to modify the front edge to gain radial clearance. Also had to widen to gain lateral clearance for turning. If I want to raise the ride height 1" higher, I would not have had to touch the wheel wells. Not sure how much bump travel I will experience?? That is the variable. I can spring the car real stiff and minimize travel but afraid it will ride too rough. ?? Any input on amount of travel experienced and with what spring rate, or better yet wheel rate?
Bob
