JavmanBBG
12-17-2014, 08:42 AM
I have started piecing together a Procharger system for my AMX I know there is 1 kit available but it is very spendy and has no IC and I think I can piece one out for around $4-4500 with careful purchasing.
I know I will have to have brackets built and adapt mounting locations of other accessories to match what I come up with.
Biggest questions are
What crank pulley are people running and how are they incorporating the alt and possibly AC or what SBC pulley options are available? I was thinking possibly 2 V belts and a 12 rib or there are serp. pulleys available for AMC but there 6 rib do they make a pulley with both 12 and 6 and possibly a water pump pulley that would be a match?
Second, are there counterfeit Big Red BOV's and is that what is running around eBay as new no box?
And I guess just any other general info on building a kit for a car that doesn't currently have one available like material and thickness for the brackets so the don't bend.
What I have purchased so far:
super damper for AMC to use SBC pulleys.
Standard rotation D1SC head unit. Suppose to be new, will figure it out when it comes in.
12" x 30" by 4.5" Procharger cross flow IC.
Also suppose to be new, same thing it is in transit.
So far I am @ $2400 spent on the 3 items.
I know of a shop that has the know how and equipment to build the custom pieces and will generally do so reasonably if you can wait for a break in there normal production. As well as have people that can weld up steel or alum. tubing
