View Full Version : 1969 camaro bumper installation
terrydmorgan
12-14-2014, 08:26 PM
I'm installing the front bumper on my 1969 Camaro and have managed to confuse myself. I have 4 carriage bolts - 2 short and 2 long. The short bolts are too short to extend through the uncompressed rubber grommets at the outer mounting point. The longer bolts reach through the grommets, but are too long and come into contact with the front valance. Seems like I should use the longer carriage bolts for the outer mounting points and then cut off the "extra" length before mounting the bumper on the car.
Anyone else experience this issue?
69L48Z27
01-26-2015, 04:43 PM
The 2 long bolts are for the outer mounts. Cut the bolts shorter if the are so long they get into the body. Bolts should be long enough to get nut on when no bushings are compressed.
terrydmorgan
01-26-2015, 04:59 PM
Thanks. I ended up installing the un-cut long bolts through the rubber bushings and outside mounting brackets while bumper was not on the car. Before mounting the bumper, I cut off the extra length of the bolts. The rest was a piece of cake.
