View Full Version : Best Octane Boost
Forum Members
Would like to get some suggestions on the best octane boost available.
I'm in CA and our pump best is 91 octane.
go-fish
12-01-2014, 05:48 PM
I use Lucas octane booster form any of your chains like Oreilly's and NAPA. I live in Cali too and it gets expensive putting octane booster in every tank. I think I'm going to take some timing out to run 91 octane. The website says it's for motorcycles but in the stores the bottle doesn't specifically say it's for this or that, just gasoline engines. Here's a link : http://lucasoil.com/products/fuel-treatments/lucas-octane-booster
Lucas Motorcycle Octane Booster - A Real Octane Booster! Tested and proven to deliver three times more boost than most other brands. Lucas Motorcycle Octane Booster is a GENUINE Performance Enhancer! Tested and proven to deliver three times more boost than most other brands. It's safe for turbos, oxygen sensors and catalytic converters. Stops knocks, and raises MPG in high compression engines.
One 15 oz. bottle treats up to 25 gallons of fuel. Not street legal.
Safe For Any Gasoline Engine
Key Benefits
Safe for turbos, oxygen sensors and catalytic converters
Suitable for use in fuel injected and carbureted engines
Provides more boost than most other brands
Promotes clean fuel burn for fewer emissions
snappytravis
12-01-2014, 06:03 PM
I use Torco, Ted Jannetty lined me up with it, I buy it off ebay. Comes in qt cans I believe just add one when I fill it up.
Bad94
12-01-2014, 07:01 PM
I use Boostane https://www.boostane.com/
Schwartz Performance
12-01-2014, 07:25 PM
I used to work at autozone and oreillys.. Best one that I read the label on was NOS brand. Some say "raises your octane by 10 points!!" Then in the fine print "1 point = .1 octane level" .. Literally .. lol.
-Dale
Any thoughts on Royal Purple Octane Boost?
Or just Royal Purple products in general?
I hear one side that octane boost is a gimmick vs the other stating they've seen performance increases with them.
I am running fuel injection so I assume the cpu will adjust according to the fuel type. Is octane boost like crack? Once you start you can't stop?
67gtonut
12-02-2014, 05:31 PM
I use Octane Supreme
http://www.wildbillscorvette.com/octanesupreme01.htm
Real Lead, and real FULL points of octane boost....
dirty rick
12-02-2014, 06:06 PM
Mix race gas with pump gas, no little bottle of jiz is going to substantially improve any quantity of gas.
Off the shelf boosters are 100% snake oil.
Pick a leaded or unleaded race fuel to mix.
Also find a station that sells a lot of premium, since most premium pump gas is stale due to lack of sales.
shmoov69
12-02-2014, 09:48 PM
^^What he said!!!^^
Unfortunately race gas is not convenient to where I live. By the time I got to the closest 100 octane station, I would have to fill up, and would be empty by the time I got home.
shmoov69
12-03-2014, 08:20 PM
I'd seriously think about ordering a drum and have it on hand in the garage. It's not as bad as what you may think cost wise.
fun2run
12-04-2014, 06:28 AM
Torco or Octane Supreme have been proven in labs to back up what they state. They are the only real deal and you won't find anything legit in auto parts stores.
Thanks for the input guys.
carguykeith
12-09-2014, 08:04 PM
How about LL100? You can't have cats and its hard on wide band O2s but cheap and available at any airfield.
I think I'm going to try out Torco Accelerator. Seems to be the most intuitive way to boost octane by simply adding concentrated race fuel.
Red67Mustang
12-14-2014, 05:38 PM
I've heard good things about this product, but haven't tried it yet myself.
http://race-gas.com
speedfreak391
02-02-2016, 08:22 AM
I use REV-X Adrenaline in my premium and haven't had a lick of problems since. Benn using it for about 2 years now and no detination at all. If I run without it, my motor sounds like a box of marbles got run through it. Here is their site.
https://www.revxoil.com/REV-X_Adrenaline.aspx
- - - Updated - - -
pittpens24
07-11-2018, 11:21 AM
How did it work out for you? I am going to try Boostane. seems a little more concentrated than Torco and not supposed to turn your internals and plugs orange.
