View Full Version : Kore3 zo6 rear brakes + Rear Diff options
formula350
11-29-2014, 06:26 PM
I'm going the kore3 route for my brakes and would like a little enlightenment concerning the parking brake and differential. I would really rather use a cable brake over a wet system.
As far as I've investigated so far it seems I have a few options.
1) Run a stock housing and keep the cable parking brake.
2)Run a Moser 9"/12 bolt and loose the cable parking brake.
3) Hope that someone here can tell me how to get the best of both worlds.
Ryan
130fe
11-29-2014, 08:06 PM
Ryan, what is a wet system? I am using the cable with my Kore 3 stuff and 9 inch, it works great. BTW, what part of SD are you in? I just moved to Chula Vista a couple of weeks ago.
formula350
11-29-2014, 09:18 PM
I mean hydraulic e-brake. Is yours a moser or just a Ford 9"?
How do you like it here? I live in downtown.
XLexusTech
11-30-2014, 07:38 AM
Confused... I run kore3 zo6 breaks with the optional parking brake kit... What's the issue?
I run a 9 inch
TheJDMan
11-30-2014, 07:43 PM
You do not want a hydraulic park brake system. Every hydraulic system, no matter how well sealed, will leak down over time. It may take a long time but it will eventually release the park brake. That is why cable actuated park brakes are the norm. If you are running a conventional "bearing on axle" setup the stock park brake system is the most cost effective way to go. However, if you are running a floating hub rear end like my Moser floater, a separate park brake caliper is about the only alternative available.
This is the park brake calipers I will be installing shortly.
http://www.ipsco.org/Custom%20Services/Parking%20Brake.htm
I will operate them with this.
http://www.summitracing.com/parts/esc-esk001
Later-A-body
12-01-2014, 03:47 PM
The KORE3 kits are available with a factory parking brake. All proven GM products. I don't understand why would you need to invest $800-$1000 into an aftermarket parking brake kit?
TheJDMan
12-01-2014, 04:34 PM
Well then I guess I don't understand what you were asking in the original post.
csouth
12-01-2014, 07:26 PM
I think the OP's post is a little confusing.
I looked at those calipers you listed a while back, looks like the ones the GMR used to carry. Seems like pinion mounted parking brake would work with a floater too...
formula350
12-03-2014, 03:40 PM
JDM thats exactly what i was talking about.talking about.
I wanted to run the full floating hub moser 9" and Kore3 with a parking brake.
The full floater rear will not work with the stock parking brake.
The first link had an error I saw the electric brake on the second one.
XLexusTech
12-03-2014, 03:55 PM
Floater rear... Critical detail missing from the original post
csouth
12-03-2014, 07:29 PM
You can use those calipers that Steve has shown you or if you really want to use the factory style backing plates do what Ron did here in post #24
https://www.pro-touring.com/threads/103106-Full-Floater-Kit-for-Dana-60-rear-axle/page2
You'll have to make your own custom rotor hat adaptation.
TheJDMan
12-08-2014, 06:54 PM
The floater rear makes parking brakes a challenge. I looked at the pinion park brakes but that requires a rotor mounted on the pinion yoke. The pinion kits are really cost effective but I was concerned about ground clearance and frankly it looks like a truck park brake. The IPSCO spot calipers are very nice pieces, I have them already, but they are more money. I just need to fab a simple weld on mount then use the E-Stopp actuator to control them.
