View Full Version : Wilwood hubs with Kore3 brackets
gray86hach
11-27-2014, 06:13 AM
I am installing c6 z51 brakes on a 79 z28.
Have the rotors, calipers, abutment brackets and kore3 brackets. I need to get hubs I was going to turn my stock rotors down and make them but I don't have access to a lathe anymore.
I can buy wildwood hubs for $112 each just not sure if the spacing is correct.
Tim
Staged 2Discover
11-28-2014, 04:07 AM
Tim
On my A body, I used "Right Stuff" forged aluminum hubs ( cost a little over $100 pr) with Kore 3 brackets. I simply used two stacked washers (of equal thickness) as shims, between the abutment and bracket to get the caliper to sit right. Forget what the actual stacked thickness was.
These hubs are not listed in their catalog as a separate item but if you call them they will sell them to you and they come with studs. Just another option for you.
Tom
gray86hach
11-28-2014, 05:02 AM
Ok I will call them
Tim
Buryingthesun
12-09-2014, 08:54 AM
Kore3 also makes hubs
