View Full Version : new wheels on my 68 firebird
ksshepard
11-25-2014, 08:44 PM
ok im new on this site so im not sure if this is the correct forum for the question but im hoping someone can help me. i want to put a 18x7 wheel on front of my 68 firebird. can this be done with out major mods and if so anyone know what i should have for back space and offset to fit it?
mikewoods
11-26-2014, 05:36 AM
18x7 should be no problem depending on how low the car is and the tire size you want to run. My car is pretty low and I run 17x8 with a 245/45/17 tire with 5.125 backspace on my 68 bird. Its really all about overall tire size. I use: http://www.rimsntires.com/specspro.jsp to play with offsets and tire widths until you get the numbers you want.
captainofiron
11-26-2014, 07:11 AM
From: http://firstgenfirebird.org/f-a-q/maximum-wheel-and-tire-sizes/
The March 2000 issue of Car Craft has an article that deals with maximum wheel and tire sizes for various cars. It has a section on the 1967, 1968, and 1969 Camaro and Firebird and below is the text of that portion of the article.
1967, 1968, and 1969 Camaros and Firebirds
15-inch: 15X8 with 4.5-inch backspacing front and rear. With some tires the rear shocks will have to be mounted inboard; if you do that, some combinations of 9-inch wheels will work with 5.5-inch backspacing.
16-inch: 16X8 with 4.5-inch backspacing front and rear. The rear shocks will have to be relocated inboard. Use tires with an aspect ratio of 50 or less with section widths of 245 to 250.
17-inch: 17X9 with 5.5-inch backspacing front and rear. There may be lower control arm contact with some steering gears. Use tires with an aspect ratio of 40 or less and section widths of 245 to 255.
18-inch: 18X9 with 5.5-inch backspacing front and rear. Use tires with an aspect ratio of 35 or less with section widths of 245 to 25 in front and 275 in the rear.
ksshepard
11-26-2014, 09:46 PM
thanks guys i will look into those.
bs46488
12-01-2014, 09:36 AM
I'm curious, why a 18x7?
I put a 17x7 on the front of my Nova and wish I went 17x8.
67CamNKC
12-01-2014, 11:32 AM
I went with 18x8 Chicanes with 4.875 bs on the front and 18x9 on the rear with 5.25 bs. Here's my 67 camaro.
106011
