Onebadbowtie86
11-23-2014, 05:08 PM
putting an ls2 in my 86 monte carlo ss, selling the 383. only 700 miles on the 383.
383
4 bolt main 1 piece rear main seal block.
Bored .030" over, zero decked .024" removed, 10.3:1 C/R
Eagle crank and rods, hypereutectic pistons, Total seal Gapless rings, internally balanced
Comp cam custom grind from Mike Lewis @Lewis Racing Engines
Cam is a billet Core, Hydraulic Roller
.586/.574 lift with 1.5 rockers
236/245 duration @.050 107 lsa
AFR Eliminator cnc ported 195 heads with upgraded hyd. Roller springs. Crane 1.5 roller rockers.
Rpm air gap intake
Pro systems 780 carb
Mallory billet distributor, accel coil, Jacobs ignition box with rev limiter
110 gph fuel pump, ceramic coated long tubes and summit mini starter all included.
All of the front accessories also included. Engine runs absolutely great and fast.
The engine is still in the car and can be heard running. No leaks or burning oil. Everything is included for this engine, its dialed in just hook it up and go.
$4000 for the engine
Will consider serious and reasonable offers.
https://static1.pt-content.com/images/pt/2014/11/383_zpsa7c79018-1.jpg (http://s245.photobucket.com/user/onebadbowtie86/media/383_zpsa7c79018.jpg.html)
https://static1.pt-content.com/images/pt/2014/11/3832_zps551f9e15-1.jpg (http://s245.photobucket.com/user/onebadbowtie86/media/3832_zps551f9e15.jpg.html)
https://static1.pt-content.com/images/pt/2014/11/hoist_zpsa56793c3-1.jpg (http://s245.photobucket.com/user/onebadbowtie86/media/hoist_zpsa56793c3.jpg.html)
https://static1.pt-content.com/images/pt/2014/11/383drive016-1.jpg (http://s245.photobucket.com/user/onebadbowtie86/media/383drive016.jpg.html)
383
Rpm air gap intake
