View Full Version : Turn Signals Don't Blink
mtmace
11-18-2014, 10:05 AM
I just replaced the bulbs in the front facing turn signals (1157NA) of my 1981 Camaro. I think the originals were clear or they could have been faded.
After I installed and tested them they turn on but they don't blink.
Any ideas why?
Isn't the flashing component connected to the fuse box?
I saw no noticeable rust or corrosion in the bulb socket.
Schwartz Performance
11-18-2014, 10:23 AM
Your flasher could be bad or there's a short/ground issue somewhere perhaps.
It's a silver cylinder on the fuse box, pretty easy to spot. They're a few bucks at the parts store.
-Dale
mtmace
11-18-2014, 10:26 AM
Thanks for the reply. I will check the grounds then replace the cylinder.
It is just strange how 1 second it worked and now it does not.
It could be the ground too. I had to fight with the bulb to remove it. Maybe I pulled a wire out or something.
mtmace
11-19-2014, 08:43 AM
Just an update, the flasher was the problem.
Thanks for the help.
Ron Sutton
11-19-2014, 09:46 AM
Was it low on blinker fluid?
105446
:cheers:
lzdick
11-19-2014, 12:30 PM
I use it all the time, Ron...LOL
Ron Sutton
11-19-2014, 12:38 PM
If you run low on blinker fluid ... we're running a special for $19.99 a gallon. :)
TheJDMan
11-19-2014, 03:12 PM
Is it synthetic?
Ron Sutton
11-19-2014, 03:18 PM
Is it synthetic?
Steve ... for $19.99 a gallon ... it's whatever you want it to be.
:yeah:
minendrews68
11-30-2014, 06:26 PM
Ron, do you by any chance carry the muffler bearings for my '68 Camaro?
Ron Sutton
11-30-2014, 08:10 PM
Oh Carl, Carl, Carl ...
You know we do!
Do you want yours in the double roller, angular contact or micro polished ceramic models?
:cheers:
