View Full Version : TIG welding, fingertip or foot pedal control?
Samckitt
11-05-2014, 06:44 AM
Which do you prefer & why?
ChevelleNV
11-05-2014, 07:12 AM
foot control... just like driving, plus that's all i have ever had never tried fingertip control. I think it would be a little distracting trying to throttle the welder while I am moving the torch around with my hand. don't even want to try it unless i was in a position it just wasn't possible to use a foot pedal.
dontlifttoshift
11-05-2014, 07:56 AM
Foot Pedal. I use the fingertip control once in a while but that is rare. If I had to pick one it would be the pedal.
Peter Mc Mahon
11-05-2014, 08:06 AM
Foot pedal, for me it allows much better control of the torch.
Typhoon1015
11-05-2014, 04:24 PM
I have both and I prefer the foot pedal it is easier to get the torch in position and at the right distance, and worry about power with the foot. thumb control seems very awkward for me unless I need it in hard to reach areas.
MonzaRacer
11-06-2015, 07:31 PM
Ok so Jody on weldingtipsandtricks.com built a simple foot control knife switch for use on an old AC Lincoln/Miller TIG box.
It uses simple thing, clipping welder electrode too tig torch.
Since he was gonna show how to run stainless and you need to cut power but keep shield gas till it cool or weld sugars.
made from hinged boards, and 600 amp battery cut off knife switch.
Pedal or thumb control , either work and practice makes perfect.
Also go check the tip Jody has for TIG welding, like gas lenses, using 2% lanthanated for all welding. Jodys video on TIG electrode choice made me a believer.
Honestly ,find someone with both setups or store that lets you try different setups.
raustinss
11-06-2015, 11:42 PM
Foot....fingertip is another thing that the same hand is trying to do while you are looking to control the arc length, angle,tungsten stickout,travel speed etc. The other hand is adding filler material. Leaving both feet to do nothing.making one of them control the "throttle" is a much easier task
showdog75
01-31-2016, 07:03 PM
I tig weld for a living and also do quite a bit at home for myself and side projects. I like both. They both have there place imo. For 99% of aluminum I like a foot pedal. For anything else I like a on/off button most of the time. My home machine is a Miller Dynasty and I'm able to set up my parameters to suit my style, likes, and needs. It's much much easier to weld out of position not having to worry about a foot pedal. Most steel/stainless can have the heat seat and welded throughout no so with aluminum which is why a foot pedal is my go to on aluminum. Aluminum takes mucho amps to start then you must back way off at times.
