View Full Version : Ssbc brake kit
cutlassmann
11-03-2014, 06:09 PM
Want to know if i can use bracket, line etc off my ssbc kit on another kit like baer and wilwood if I just want to buy the calipers are will i have to buy a hole the kit.
andrewb70
11-03-2014, 08:14 PM
Probably have to get the whole kit.
Gratefuldiver
11-04-2014, 04:34 AM
It depends on what Caliper you are using now. I bought an aftermarket rear disk kit that had the caddy calipers with e brake. I was able to install a Wilwood D154 calipers in place of those using the existing brackets.
OG_Racing
11-04-2014, 06:36 AM
^ yep if you have a circle track type caliper you should be able to swap those over. get an engineering drawing (blueprints) from ssbc and i might be able to direct you to what will replace it.
