View Full Version : DSE Frame T56 Magnum Crossmember
badazz81z28
10-29-2014, 10:20 AM
What are you all using with the Camaro DSE Frame and an LS/T56 set-up? I got one direction, but looking for more ideas before I commit.
Z06vet
10-29-2014, 01:09 PM
I used Speed Tech crossmember on my first gen DSE frame. Lot of adjustability, fit well. I have used these in a stock first gen subframe as well with good results.
Scott
TheJDMan
10-30-2014, 12:10 PM
Scott
Scott,
How is the clearance between the crossmember and the header collectors?
Z06vet
10-30-2014, 12:28 PM
Its was good on a stock subframe. I'm hoping to test fit the motor/trans/headers (stainless works) in the DSE subframe in the next week or 2. Waiting on some parts to button up the motor.
Scott
D.Alman
10-30-2014, 05:37 PM
Which motor mounts are you guys using with the DSE Frame ?
spacepirate
10-30-2014, 05:43 PM
I have the DSE subframe and American Powertrain cross member. The engine should be going in this week. I'll keep you posted on how it fits.
I'm also using Speedtech's body mounts and headers.
Z06vet
10-30-2014, 07:31 PM
I'm using the DSE 1" setback stands/mounts. I'm running C6 oil pan which requires the setback, which should also give a bit more room for header clearance. Will have pics in a week or 2. Looking forward to the pics with the speedtech headers referenced above.
badazz81z28
10-31-2014, 06:25 AM
I'm using the DSE set-back mounts as well. I need to use a first gen crossmember, but since it's going in a second gen, I'm real curious about the APT. I hear the first gen has floor pockets that the crossmember tucks in, which would be a problem for a 70-81.
D.Alman
10-31-2014, 04:06 PM
I will be following this thread , will be doing the same setup with DSE frame LS3 and t56 in 67 camaro .
badazz81z28
12-14-2014, 02:29 PM
Any updates on the APT crossmember? Doesnt lool like the Speedtech is going to work out.
spacepirate
12-14-2014, 06:32 PM
The engine went in good with the DSE set back mounts, ATP Xmember and Speedtech headers. I'll try and get my shop to take some pictures for me to post. The set back on the mounts made the engine fit very close to the firewall but it did fit!
badazz81z28
12-14-2014, 07:00 PM
Would you remind me again if the car was a sec or first gen? Pictures would be awesome!
spacepirate
12-14-2014, 08:44 PM
1968 Camaro. Here are the only pics I have at the moment. I'm away from my shop for a couple weeks but I'll try to get some better ones as soon as I can.
106469106470106471
MarkB
12-17-2014, 06:05 PM
We have a two piece bolt in tubular crossmember that will work for your application. You can check it out here. http://bowlertransmissions.com/p/482/crossmember-for-1967-1969-camaro-with-ls-engine-t56-transmission
Let me know if you have any questions. Thanks for taking the time to check out our products.
Mark
badazz81z28
12-18-2014, 06:20 PM
Mark, Sent you a PM
D.Alman
12-29-2014, 02:20 PM
How does the steering shaft work out with the speed tech headers?
spacepirate
12-29-2014, 04:27 PM
We haven't had a chance to mock it up yet but it looks like it should fit just fine.
American Powertrain
01-07-2015, 11:44 AM
Our F-body crossmember works great with DSE sub frame. Our aluminum crossmember is also adjustable so you can dial it in for setting your engine back. Low profile and light weight.
http://americanpowertrain.com/i-8425882-x-factor-aluminum-cross-member-67-69-f-body-and-68-72-x-body-to-gm-magnum-t56-viper.html
Matt G
icemanrd19
05-08-2015, 07:50 PM
Hooker t56 crossmember. This crossmember would have been perfect if the top part of the arc wasn't soo high. Right now I'm cutting the hat off of each of them and tomorrow i will weld a plate underneath the arc instead of on top.
https://static1.pt-content.com/images/pt/2015/05/20150508_222856_resized-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/20150508_222856_resized.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20150508_220448_resized_1-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/20150508_220448_resized_1.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20150508_220608_resized_1-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/20150508_220608_resized_1.jpg.html)
https://static1.pt-content.com/images/pt/2015/05/20150508_220538_resized_1-1.jpg (http://s30.photobucket.com/user/icemanrld19/media/20150508_220538_resized_1.jpg.html)
