    Results 1 to 12 of 12
      Nov 2013
      4 gen - 1st gen IRS swap
      I am working on a 67 Camaro. The original plan was to put a 4-link suspension in the rear But my friend was telling me about the IRS suspension set ups the have now. I was looking around and saw that IRS set ups for a 1st gen are not cheap, But we were thinking we could swap the IRS from a 5th gen Camaro into me car.
      I am wondering if that's something that would work.
      thanks
      Oct 2013
      I'd cost you way more to fab that 5th gen irs into your car track width is way off and also irs I believe will require you to use a 2 piece drive shaft
      Apr 2012
      Woodstock, IL
      Yep it'd be expensive to adapt all of that unless you're fabbing yourself. Cheaper way to go is adapting something older like a Tbird or Mustang Cobra.
      -Dale
      SchwartzPerformance
      Nov 2013
      Ok, I'm new to the IRS system. What all needs to be modified to fit?
      Aug 2011
      Connecticut
      I plan on installing one on my 1967, But im also doing all the fab work myself.
      1967 Firebird "Poor-Boy Build"
      New updated thread
      https://www.pro-touring.com/threads/...bird-(Updates)
      Follow me on Instagram @NaturalLivingMan
      Aug 2011
      Connecticut
      Quote Originally Posted by 71maroesteban View Post
      Whats do you deem way off to be? proper off set wheels can resolve a track width issue
      New updated thread
      Aug 2011
      Connecticut
      MATH/FACT POST
      2010+ Camaro V6 model is 64.1" and V8 is 63.7" and front is 63.7' on both, factory axle width on my 1967 Firebird is 62.5" so the "track width" is not really relevant here
      New updated thread
      Anniston, Al
      I actually bought an IRS setup out of a 2001 Lincoln LS. I haven't had a chance to start working on it but you can get them dirt cheap and the cradle looks like it should fit well. There are 4 mounting points and the rear points are higher than the front. Some IRS setups I looked at had all 4 mounts level so it seems like it would take more work to make that type fit. I wouldn't consider doing this if I had to pay someone to do the fab work though.
      1967 Firebird (current project)
      1967 Firebird (unfinished project SOLD)
      Aug 2011
      Connecticut
      Quote Originally Posted by Wall View Post
      I'm using the Camaro/G8 rear because of the aftermarket support and the fact I can literally go to any part of the country and get a part to fix it
      New updated thread
      Anniston, Al
      Quote Originally Posted by Buryingthesun View Post
      I am rethinking the Lincoln IRS now. I didn't realize the G8 and Camaro IRS were the same but I may have to check those out.
      Dec 2009
      Carson City, NV
      Well the Late model Camaro IRS will fit, but it will take a lot of fab work. here's one in going in my Chevelle
      Sep 2010
      Beach Park IL
      MATH/FACT POST
      Pretty sure that hub to hub on a stock 1st gen is 60". If the numbers you posted for the late model are track width numbers (tire centerline to tire centerline) then you can plan on a hub to hub of at least 65" for the late model rear end. yes you can still fix it with offset in the sheels but will the IRS take 9" of backspace?
      Donny
