MAP
10-22-2014, 04:37 PM
For sale: 383 SBC 1 motor designed by engine design expert extraordinaire David Vizard* and extensively computer-modeled. As shown below, total amount invested $11k. (Gulp! I almost wished I hadn't added those receipts to find out...)
https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_1095.jpg.html)
High quality parts were used throughout: 3970010 high-tin GM block, forged everything, roller everything, AFR 195 "Eliminator" CNC heads, 10.5:1 SCR, Edelbrock RPM Air-Gap port-matched to heads, custom Comp Cams hydraulic roller designed for maximum torque and good low-speed output. Goal was absolute maximum performance consistent with 25mpg with a carburetor, 60 mph hwy cruising. Modeling (Engine Analyzer Pro) showed 26 mpg with target drivetrain, 510 lb-ft peak at 4,000 rpm and 470 hp pk at 5,800 rpm. David predicts 500 lb-ft and 460 hp pk. In a 3,500 lb A/G Body, David predicts “4.0 sec 0-60, but traction-limited deal, otherwise 3.2 sec.”
This motor has an interesting history: it was originally targeted to be a 500 hp design with a longish duration CC hydraulic roller cam, and I drove the car with this motor for about 500 miles. It was a beast to drive: it could easily smoke the tires if you stabbed the throttle at 80 mph. But I got tired of only 10 mpg. This was with the wrong gearing and the wrong torque converter, but I still knew the cam was too big. So out came the motor and this was when I brought-in Mr. Vizard for extensive consultation for the 25 mpg cruising target, as I intended the car to be a daily driver. I consider myself very fortunate to have been able to tap into his vast knowledge base. Starting with the existing short block, on went a new set of the Eliminator heads and an unusual hydraulic roller cam spec'd by David (basically, short duration and high lift with aggressive lift ramps,) and the Air Gap manifold. Per his recommendation, the Edelbrock Thunder AVS (800 CFM) carb was spec'd along with Crane's all-electonic distributor, that with a simple setting of two small dials on the distributor base, yields an innumerable combination of mechanical and vacuum-advance curves. A lot of time and TLC went into the execution of this engine.
The new motor was finished a few years ago, but too much time has passed and the collateral project of building a "super" Monte Carlo SS has likewise never materialized. At this point I think I'm still a long, long way from getting back to car building, so with more than just a little sadness and regret, I’m putting this motor up for sale. The new motor hasn’t been fired up, but the short block has its original 500 miles during which it burned zero oil.
Please see the last section for prices because I want to be flexible to accommodate the buyer's preferences.
*David Vizard has authored about 40 books on engines. He holds 40 patents, has written some 4,000 articles and has conducted more than 200,000 dyno pulls. He is one of the original designers of the British Super Sonic Transport.
More photos: click on thumbnails to enlarge
https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/DV_SBC_project.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/DV_How_to_Build_Horsepower.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_0944.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_0950.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_0979.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_1023.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_1055.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_1060.jpg.html) https://static1.pt-content.com/images/noimg.gif (http://s663.photobucket.com/user/mapirc/media/383_Ad/100_1103.jpg.html)
Parts in base long block:
Eagle CRS6000 B3DE 6" forged rods
Exclusively ARP fasteners throughout motor
JE (SRP) forged pistons SRP-138093-030
Pins 927-2750 full floating
Rings J100F8-4030SP, gapped
SFI-64262 all steel crankshaft dampener
4340 Scat forged steel crank
AFR 1038 CNC heads milled flat for 10.5:1 SCR, AFR lash caps
Comp Cams hydraulic roller CS 3188/3312 custom camshaft
Comp Cams 853-16 hydraulic roller lifters with crossbars
Comp Cams custom-length pushrods
Comp Cams "Beehive" springs, retainers, and locks
Crane "Gold Race" narrow-body 1.6:1 roller rockers
L98 Corvette magnesium valve covers
Cloyes 9-229 "quick button" timing cover
Edelbrock mechanical fuel pump
3970010 high-tin block, 2-bolt (David Vizard says 100hp max NOx shot is safe with this block.) Bored/honed with torque plates.
Edelbrock RPM Air Gap intake manifold, extensively port/runner matched to heads
Milodon 31503 road-race oil pan
Edelbrock 8811 water pump
CSI starter
Price structure:
a. Long block (no carb, ignition, alternator, headers); Cost me $8.7k, sell for $4.9k.
b. Edelbrock AVS 18134 800 CFM, Endurashine, new in box - never saw gasoline - add $400 (Current cost at Summit: $540)
c. Crane electronic ignition system, new in boxes:
1000-1051 GM small cap distributor
730-0892 LX-92 performance coil
6000-6440 ignition control box
6000-6425 boost control module
9000-0110 boost sensor
Add $800 (Current cost at Summit: $995)
d. Hedman 65218 headers, with collectors (no coatings) - add $400 (Current cost at Summit: $534)
e. Powermaster 18207 ALT-CS-130D alternator, chromed, new in box - add $160 (Current cost at Summit: $200)
Please note items b-e will not be available separately until/unless the long block assembly (at least) has been spoken for. Shipping: local pickup in Yuma, AZ is preferable, but I'll get the motor on a pallet if shipping is needed. Buyer must arrange shipping with a truck lift from my residential address. Inquiries, please e-mail: mapler(at)adelphia(dot)net.
Thank you for reading my ad!
Best,
MAP
CSI starter
Price structure:
Best,
MAP
