Motown 454
10-13-2014, 09:30 PM
I have a new Weldon 1100A fuel pump for sale. Never used . $350 shipped Pay pal OK [email protected]
Weldon 1100-A
Bought this pump used, ran it for a few months, and sent it off to
Weldon. Weldon cleaned the "brushes" in the pump. Apparently they had
become varnished from sitting for a long time (due to bad gas before I
received it). It was cleaned, flowed, and returned to me in
essentially new condition, ready to run. When I sent this one to
Weldon, I bought a new 1100-A to get the car running while they had
mine. I received this one back and with a clean bill of health, so it
is for sale...
Here are some specs from Weldon Racing's website...
Maximum HP:
1100 hp Inj/1300 hp Carb
GPH/PSI Range:
135 GPH/0-95 PSI
Features
Extremely quiet
Smooth, precise fuel delivery
Extremely low current draw
Self Priming
Pump may be mounted above fuel cell
vertical or horizontal mount
All internal wear components are 100% metallic
No plastics or composite materials are used in the 1100-A pump. This
results in the longest lasting, highest quality most durable flow
through pump available.
The housing is made from corrosion resistant 304 brushed stainless steel
Mil-Spec Clear anodized billet end caps with No-Leak seals and
stainless steel electrical connectors
-10 inlet and outlet with leak free o-ring ports
6.25 lbs
Two stainless steel T-bolt style clamps included with each pump
Long life, continuous duty
•Compatible with Gasoline Only (not compatible with alcohol / ethanol
based fuels)
Requires appropriate bypass regulator, a -8 return line is recommended.
•This is essentially a new pump after being cleaned, flowed, and
inspected by Weldon.
•Includes everything pictured (mounting brackets, instructions and decals)
https://static1.pt-content.com/images/noimg.gif (http://s172.photobucket.com/user/Hardcore454/media/Parts%20Forsale/103_0938_zps8c30ed4c.jpg.html)
I also have a New Weldon fuel pump controller $325 shipped.
https://static1.pt-content.com/images/noimg.gif (http://s172.photobucket.com/user/Hardcore454/media/Parts%20Forsale/img-23-0-small_zpsacba1fcc.jpg.html)
Allows user to adjust the volume of fuel flowing through the system while maintaining preset fuel pressure
Controls pump speed with PWM, pulse width modulation, @ over 12,000 Hz. This means the electrical current to the electric motor is interrupted over 12,000 times per second to reduce the RPM
Over 64 times the switching frequency compared to our competition
Advantages:
Decreases pump sound level
Keeps fuel cooler
Minimizes cavitation
Prevents vapor lock
Allows you to switch between full and controlled speed
Weldon 1100-A
is for sale...
Maximum HP:
GPH/PSI Range:
135 GPH/0-95 PSI
Features
Extremely quiet
Self Priming
6.25 lbs
based fuels)
Advantages:
Keeps fuel cooler
Prevents vapor lock
