48prerunner
10-11-2014, 04:54 PM
I have 69 f-100 and I'm running a hydroboost off a 2006 super duty.https://static1.pt-content.com/images/pt/2014/10/hydroboost_zps7ced6610-1.jpg (http://s325.photobucket.com/user/ford1969/media/hydroboost_zps7ced6610.jpg.html)
I have a 2013 coyote so I'm running a KRC power steering pump.https://static1.pt-content.com/images/pt/2014/10/passsideovehead_zps75f5f35c-1.jpg (http://s325.photobucket.com/user/ford1969/media/passsideovehead_zps75f5f35c.jpg.html)
the pump is on the passenger side so it is about a 7' run to the pump. I plan on running a 3/8" hard line to an aeroquip AQR high pressure power steering hose AN-06. The fittings on the hydro booster are M16-1.5 bump tube, and M18-1.5 bump tube so I plan on using adapters to change them to AN -06. Is the hard line the best way to go? I bent up a practice line that hugs the firewall and down the pass fender. From there I'd run the braided for flex.
I've never flared 37* on a steel line do I just run a tube nut or do I need a tubing support not sure what they are called also? Would I be better off just running flex all the way?
From Hydo to power rack is a short run about 2.5 feet and i have a machined fitting to fit the crown vic rack and a -06 an fitting.
The remote reservoir will be on the rad support and I will run separate return lines from the rack and hydro.
I tried searching about hard lines just not sure about the tube nuts, Thanks for any help or advice.
