View Full Version : Aeromotive A1000 Stealth fuel cell
tommycomfort
10-11-2014, 01:19 PM
*** SOLD *** This is the fuel tank that we have been running in our wagon for a couple of years since we installed the fuel injection system. Much more capable fuel pump than we ever needed. Just removed this tank to put the stock tank (modified with the Aeromotive Phantom Fuel System kit installed) back in. No trouble with it whatsoever. I'll even include the mounting cage we built if you like. It would be an easy fit in a 64-67 Chevelle wagon or El Camino. I would really like this to be local pickup in Mooresville, Indiana, but can ship it at the buyers expense too. Or, if you meet us by the highway on our trip to SEMA we can deliver it. $500 or best offer. Tom 317 502 7460
Summit sells it for $795.97 and this is what they have to say about it:
Capacity: 20 gallons
Fuel Cell Color: Natural
Fuel Cell Material: Aluminum
Foam: No
Sending Unit Included: Yes
Sender Ohm Range: 0 ohms empty, 90 ohms full
Length (in): 24.000 in.
Width (in): 20.000 in.
Height (in): 10.000 in.
Outlet Fitting Quantity: One
Outlet Fitting Size: -10 AN
Vent Fitting Size: -8 AN
Return Fitting Size: -8 AN
Tip Over Valve Size: -8 AN
Sump: No
Quantity: Sold individually.
Notes: Includes a 100 micron stainless steel prefilter and Aeromotive A1000 electric fuel pump built into the fuel cell.
These Aeromotive A1000 Stealth fuel cells feature a built-in Aeromotive A1000 fuel pump and a 100 micron stainless steel prefilter. They can be mounted anywhere in any car. Simply strap one of the fuel cells in, hook up your fuel line to the pump outlet and your two wires, and you're done. You won't have to search any longer for a place to mount your fuel pump and pre-pump filter. Through an innovative baffling system inside of the cells, the fuel pump inlet always has a constant column of fuel. In addition, the Aeromotive A1000 Stealth fuel cells' baffling keeps fuel at that same point, even during extreme driving conditions, making them perfect for off-road vehicles, drag racing, and even autocross and drifting. Plus, the pump is inside of the cells, so noise is drastically reduced, and the fuel pump runs cooler longer, ensuring longevity and drivability.
Additional features include:
* Available in 15 or 20 gallon capacity
* All-aluminum construction
* TIG-welded
* Flush mount lid assembly
* Two -8 AN rollover valves
* Universal 0-90 ohm built-in fuel level sending unit
* -8 AN return fitting for bypass line from the fuel pressure regulator
https://static1.pt-content.com/images/pt/2014/10/DSC00940_zps8a2320bb-1.jpg (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00940_zps8a2320bb.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00943_zpsdc955cac.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/DSC00941_zps2b2a0825-1.jpg (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00941_zps2b2a0825.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00942_zps92387104.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/DSC00939_zps326c35e0-1.jpg (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00939_zps326c35e0.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s205.photobucket.com/user/tommycomfort/media/For%20sale/DSC00938_zps1a31d6b8.jpg.html)
tommycomfort
10-12-2014, 05:57 AM
PMs returned
tommycomfort
10-18-2014, 12:49 PM
Saturday bump.
Reiter67
10-19-2014, 06:41 AM
Going to be anywhere near mi? Or shipping to 48185 mi? Interested in it
tommycomfort
10-19-2014, 11:17 AM
We definitely get to Michigan quite often but won't be up that way again until after SEMA/mid November.
Reiter67
10-19-2014, 11:36 AM
I can wait . Project is coming along well and this would be perfect . I can maybe arrange a call tag or something.URL=http://s241.photobucket.com/user/fastteg03/media/camaro68.jpg.html]https://static1.pt-content.com/images/pt/2014/07/camaro68-1.jpg[/URL] this is what it is for been a long time project finally going the way I want it
tommycomfort
11-25-2014, 08:50 AM
Bump! Just purchased a new VDO fuel level sender for it. Thought we had a gauge problem but seems we might have had a bad sender. So, just to eliminate any possibility, I bought a new one. Shiny stuff always looks good under the Christmas tree! :)
Reiter67
11-28-2014, 05:45 PM
I'm still interested in this.
tommycomfort
01-03-2015, 10:18 AM
*** SOLD *** Thanks P-T.com!
