View Full Version : shock problem?
67_camaro
10-07-2014, 05:27 PM
I have 1967 CAMARO and i lowered it 4 inches from the back. Where can I buy some shocks or can I use the originals size? Thank you
Solid LT-1
10-08-2014, 09:26 PM
4" is about all the suspension travel that a 67 Camaro had....either need new shock mount locations or shorter shocks.
67_camaro
10-09-2014, 12:50 PM
Yeah I bought different shock mounts. But I'm having trouble finding shocks
bret
10-09-2014, 04:18 PM
We can build shocks with nearly any dimension and mounting style.
BUT...if your car is truly 4"lower than stock, you are completely on the bumpstops and have no suspension travel. No shock will make this setup ride well. You must have at least 2" of compression travel to have any hope of a civilized ride quality and any handling performance. When you get the car at that height, take a measurement between the shock mounts and call us. We will have a shock that fits...and works.
67_camaro
10-09-2014, 04:48 PM
What can I put in my car to drop it at a safe level? Something affordable.
dirty rick
10-09-2014, 05:29 PM
You lowered the back of the car 4"? How?
67_camaro
10-09-2014, 06:13 PM
Well today me and my dad measured it and we go 2 inches so it's a my bad, we thought we had 4 inches because we bought 2 inch drop leaf spring and put 2 inch blocks, but I think that the spring are not 2 inch drop
TheJDMan
10-09-2014, 08:26 PM
Sounds to me like you need to send some time talking to RideTech about how to properly lower your car and improve the handling in the process. Those lowering blocks are going to be problematic.
bret
10-10-2014, 06:45 AM
Yep...2" sounds more feasible. We used a 2" drop leafspring from Eaton Spring on my 69 Z28, and our RideTech tall dropped spindle in the front with a 1" extended spring from Eaton...car sits perfect and rides and handles really nice. We also built delrin bushings for the OEM control arms, installed a larger front swaybar, and installed a set of our rebound adjustable smoothbody shocks. It's proven to be a great package for the guy who doesn't want to molest an original car [like me] or for the guy who wants a gentlemans cruiser without spending $5k to get there. With a 15" tire, my Z wont corner like the 48 HR Camaro, but it is darn acceptable for a street cruiser. I was looking to improve the car as much as possible without changing the "civilian" look of the original Z28. I am truly pleased with the results. I'll post some pictures of the car soon.
We've been considering putting this package together to sell as a complete system. I don't know exactly what it would cost but certainly somwhere under $2k for the front and rear springs, front spindles, front swaybar, delrin bushings, and adjustable shocks. Think there would be any interest?
In the meantime...the answer to your original question...fixed valve shocks would run $125/each, single adjustable shocks - $175/each.
Rodney Mason at our shop can help with ordering and/or tech. [email protected] direct number = 812.481.4742
67_camaro
10-11-2014, 12:42 PM
I'm running 18x10 rear and 17x8 front what's a good affordable set up? For my camaro ?
Rod
10-11-2014, 04:10 PM
That's a broad question.....what do you consider affordable? set up of what? suspension set up? engine set up? tire combo set up? shock set up? Brake set up? also what is your intentions with the car? Auto cross? daily driver? big track? drag race?
67_camaro
10-12-2014, 10:42 AM
I planing to use it as a weekend cruiser, I have a 396 bb 500 hp 450 torque. Stock suspension, and wilwood 6 piston 12" front brakes and 10" rear brakes. I would probably spend 2500 in suspension.?
