View Full Version : ridetech castor plugs?
Kiquee71
09-26-2014, 04:02 PM
I've got my front suspension set up on my 71 Nova with Ridetech uppers & lowers, muscle bar, spindles and coil overs. I've also orders the extra castor plugs for alignment purposes. My question to you all is what castor plugs are you running with power steering in your cars? This will give a ball park setting to set up now before I have it aligned. Any info will be appreciated. Thanks
camrat68
09-26-2014, 07:45 PM
I'm running the centering plugs. 1968 Camaro, RideTech uppers and lowers with HQ coil overs and MuscleBar. When I called RideTech to order the other plugs prior to having the car aligned, they told me that they shouldn't be necessary for the street. I didn't end up needing anything other than the ones provided.
I do not have the specs for what it was set at for the alignment.
Jim
Kiquee71
09-27-2014, 08:23 AM
Thanks Jim for the response. I will leave the one that came with the kit, but now that I have the extra plugs I can use later down the road if I want to really get aggressive with it for road coarse runs.
Rod
09-27-2014, 09:29 AM
do you have the offset plugs that came with the arm or a centering plug? I believe that the slightly offset plug is 4 degrees that's the one I use, with the guldstrand works great street and track
Kiquee71
09-27-2014, 08:52 PM
The ones that I have in there right now are centered which is the way they came. I did order the extra plugs, but will hold off putting them in till I have the car aligned. Hey Rod, with the RideTech arm and center plug where will my castor be, roughly?
Rod
09-28-2014, 06:26 AM
I will ask the engineer Monday morning for you
Kiquee71
09-29-2014, 01:15 PM
I will ask the engineer Monday morning for you[/QUOTE]
Hello Rod, any info in that castor number?
gmorris
09-30-2014, 06:11 AM
On my '69 chevelle the centered plugs only got me about 3º caster without a huge stack of shims. I just got the offset plugs to try and get rid of some shims.
Kiquee71
09-30-2014, 06:52 AM
Gmorris, that's what I've been reading that the center castor plug will yield about 3-4 deg. I too got the extra plugs just incase instead of stacking up shims. Thanks for the reply, every little bit of info make things a little easier.
Rod
09-30-2014, 07:42 AM
the castor slug is about 3-4 degrees, that also depends on the frame rake, the higher the back (like when they stick those big ass 20 inch wheels on the back and 17-18-19 up front to create rake) the less the castor will be, with the correct frame configuration (level or almost) it will give you about 4 degrees with the G-mod it will be closer to 5-6 degrees
Kiquee71
09-30-2014, 09:14 PM
Thanks Rod for that info. With my Nova I'm shooting for a level stance. So if I were to install one of the extra slugs which are 1/8 increments I should be able to achieve the extra 5-6 deg castor without the extra shims. Also don't have the Gmod done to the car. Cool thanks
gmorris
10-14-2014, 06:14 AM
Some feedback on my chevelle. I just installed the #3 caster plugs and they basically put me to the same point I was at with the centered plugs and 4 very thick shims on the back bolt...3º. This allowed me to get about 6º with some shims. The extra 3º completely transformed the car. It stays centered much better, doesn't follow ruts nearly as bad and feels much more stable.
