Phillip_L
10-03-2005, 03:59 PM
I posted something about a week ago and got no replies. Some has to know where this wire goes.
I pulled my dash to put in a Covan dash panel. I also had to drop the steering column. When I was putting every thing back, I found a loose wire and followed it to the starter. Were does this wire connect under the dash? I thought it would go the white relay mounted on the steering column about half way down (about 8 wires connected to it). There are two open spots on this relay. I tried to figure out which one with a volt meter. When I turn the key, I hear a click, but not 12 volts on either open location. Am I in the right spot? The start wire looks like it from a bad patch job.
Thanks in advance.
Phillip
Thanks in advance.
Phillip
