408maro
09-24-2014, 07:06 AM
Ok I'm a lil lost here.
My 72 camaro headlights weren't working because the dimmer switch had broke. But everything else worked in car
then I get the headlights to work by installing new dimmer switch. While having headlights on i notice smoke coming from somewhere. Well I track it down to a ground for a cheap temp gauge light...so I just remove the light and wiring all together. And I thought all was fine
Well i thought the battery died because I had door open for a while so I jump it and notice that the lights don't work. Outside or inside
And radio don't come on either. Also the dome light comes on but once I turn the ignition the dome light goes off
The car starts and runs but no radio. No lights and dome light issue. I checked all fuses all look ok
Here's something to add to that. I put a test light to fuses with key on and nothing but when key is off they light up
Battery was fine whole time starts normal every time
The dome light comes on with door open but once ignition is in on position turns off and if I turn headlight to on shuts off. Still no radio or any blinkers functioning however noticed that fuel gage works when turning key to on position
Getting 12.4 volts at horn relay with key on and 12.6 with key off
Unplug a connection with 5 wires at square looking box next to radiator and canister and light shuts off and has constant 12 volts
Any other thoughts?
thanks john
Any other thoughts?
thanks john
