View Full Version : 69 camaro trunk battery confusion!!!!!
sweet motion
09-19-2014, 12:44 AM
:dunno:Can anyone recommend what battery to put in my trunk??I also like the idea of mounting a bat. tender there too.Any particular brands of both to use!? It's an ls3 w/procharger-pw,el,f pump,ac, lots of electrical hungry stuff,THANX for any help!!
TheJDMan
09-20-2014, 07:46 PM
You absolutely need an AGM (Absorbed Glass Mat) battery. I prefer Odyssey but many use Optima batteries. If you need some basic battery info here is a good article.
http://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html
H2Ogbodies
10-09-2014, 07:18 AM
How is your charging/underhood wiring configured? Pics? There's a lot of upgrades you should take advantage of that is not present in any aftermarket wiring offering that I've ever seen. PM menif that's easier-I can give ya my phone number to chat about it, too. For example, I'd like to see you have nearly NO voltage drop at any point around the car while operating your accessories. Plus, with a battery relocation-are you ever gonna drag it? If so, you need a cut-off switch, battery requires an enclosure, too-which needs to be grounded and vented.
JEFFTATE
10-09-2014, 07:40 AM
For my street/ pro-touring / occasional event Camaro , I have a metal Taylor Battery Box and wiring kit I bought from Lane Automotive/ Motorstate/ Allstar in Michigan .
The metal Taylor box is sealed and vented.
The wire kit is fine strand and flexible .
I use a standard GM AC Delco 78 series battery .
I put a 1.5 amp trickle charger on it every week or two if I haven't been driving it often .
In the winter , I pull the battery out of the car and charge it on my workbench.
I've never had a problem with fluid or acid leaks .
DreamRyder1963
10-09-2014, 12:43 PM
There are also small mountable battery tenders available for about $30. All you would have to do is plug it into your wall outlet when the car sits.
67rally
10-20-2014, 12:57 PM
I use a Yellow Top Optima in my '67 with an LQ9. I used the MAD Electrical solenoid in the trunk and distribution blocks under the hood, 8 awg wire from the alt to the battery, and 1/0 from the battery to the starter.
70LS1NOVA
10-28-2014, 07:47 AM
I have the Optima Red top battery in my 70 nova with an LS1. Been in there for 10 years now with no issues. It sits in my garage all winter without the trickle charger and still starts in spring. I do use the cutoff switch though and turn it off at end of season. Spring comes, I charge it overnight on a 2 amp charger. Drive all summer and most of fall. I take the car drag racing and was under the impression I needed a box. I bought the moroso plastic box, but never installed it. Tech inspection never told me I needed it.
