View Full Version : Wilwood Superlite 6R Big Brake Front Hub Kit 140-12280 D 2nd gen camaro/firebird NEW
aronhk_md
09-16-2014, 10:24 AM
The kit is new, never used. I am going in a different direction and changed my mind on using this. To take pictures I would have to take everything out of the box. The price on ebay and Summit etc is $1299 plus shipping.
$1000 plus shipping or pick up in West Chester, PA 19380
This is the drilled rotor kit and fits 79-81...but, if you are willing to switch your earlier year spindles out for a set of 79-81 you should be able to use these on any year 2nd gen bird or Camaro.
Including a description I found below with fitment.
Features Drilled & Slotted Rotors, as well as Powder-Coated Black Calipers.
Fits:
Buick:
1979-1985 Estate Wagon with OE Spindles that were used with 11" diameter rotors
1979-1985 LeSabre with OE Spindles that were used with 11" diameter rotors
1979 Skylark with OE Disc Brake Spindles
Chevrolet:
1979-1981 Camaro with OE Disc Brake Spindles
1979-1990 Caprice with OE Spindles that were used with 11" diameter rotors
1979-1985 Impala with OE Spindles that were used with 11" diameter rotors
1979 Nova with OE Disc Brake Spindles
Oldsmobile:
1979-1985 Olds 88 with OE Spindles that were used with 11" diameter rotors
1979-1985 Custom Cruiser with OE Spindles that were used with 11" diameter rotors
1979 Omega with OE Disc Brake Spindles
Pontiac:
1979-1981 Bonneville with OE Spindles that were used with 11" diameter rotors
1979-1981 Catalina with OE Spindles that were used with 11" diameter rotors
1979-1981 Firebird with OE Disc Brake Spindles
1980-1986 Parisienne with OE Spindles that were used with 11" diameter rotors
1979 Phoenix with OE Disc Brake Spindles
Wilwood brake kits consist of specifically engineered & matched groups of components designed to provide superior brake system performance & custom appeal over a wide range of applications.
Forged Narrow Superlite 6 piston calipers with 12.90" diameter, 1 piece rotor and hats kits deliver the cost effective combination for braking power and style in this group of kits engineered for traditional non-ABS spindles on American muscle cars and vintage rods. Built exclusively for 17" and larger wheels, FNSL6 kits enhance tire and suspension upgrades on all types of custom show and high performance dual-purpose street and track machines. These kits are guaranteed to catch the eye of the most discriminating enthusiast while providing optimized brake performance for every individual application.
These Big Brake kits require at least 17" diameter wheels.
Kit includes parts for both front wheels:
Drilled & Slotted, 1.10" Thick x 12.90" O.D. 1 Piece Rotors
Forged Narrow Superlite 6 Piston Radial Calipers - Black
Caliper Mounting Brackets
BP-10 Smart Compound Brake Pads
Brake Hubs
Bearings, Races, Seals, Dust Caps, &
All bolts, shims, washers, & nuts necessary to install the complete braking system on both front wheels
Complete kit weighs approximately 60 lbs
Assembly instructions link
http://www.southwestspeed.com/docs/WIL_140-12280Instructions.pdf
aronhk_md
09-25-2014, 11:24 AM
I'll either ship for free or knock $50 off the price for pick up
aronhk_md
10-06-2014, 05:29 AM
Anyone want to make an offer before I try ebay?
Nova70
10-06-2014, 07:24 PM
will they not fit 70 model gm?
Graham355
10-09-2014, 12:30 AM
Pm sent
aronhk_md
10-09-2014, 03:19 PM
My understanding is it can fit a 70 if you change the spindles to a later model spindle. What I don't remember is if you need to change any of the smaller stuff, like tie rod ends. You can call Wilwood and they'll give you the scoop.
Colin70ta
10-09-2014, 07:20 PM
PM Sent!
Nova70
10-10-2014, 11:53 AM
I've got the ride tech steering and spindles but its for 67-69 camaro/68-72 nova
