View Full Version : does turbo tubing need to be rolled at the ends?
Y-TRY
09-07-2014, 06:50 PM
Are there any options for securing a tight seal at a coupler on turbo plumbing, when the ends aren't rolled?
Schwartz Performance
09-07-2014, 07:53 PM
How much boost? You can get by with lower boost applications and no rolls.. For extra safety you can double up on clamps too.
Vibrant sells a mini bead roller that we use on tubing, it's pretty cool but I think it's a couple hundred dollars .
-Dale
shmoov69
09-08-2014, 02:29 PM
I ran for about 8 or so years with just straight cut ends and good hose clamps. I added bigger turbos (=more airflow) and blew the pipes off a couple times so I welded a couple spots of beads around the edge of the pipe and it hasn't had any troubles since. Bead roller is nice but weld is cheap! LoL!
Y-TRY
09-08-2014, 02:50 PM
I've been running straight cuts and welds, like Schmoov69. Now I'm having to trim the intercooler inlets. Doing so cuts off the beads on the ends and since the tubes are welded to the cooler it's near impossible to re-do them with a traditional roller.
72BBSwinger
09-08-2014, 06:56 PM
Hairspray on the tube before you put the hose on.
