View Full Version : stumble troubles
RobM
09-28-2005, 07:59 AM
My car has trouble bogging really bad when I launch the car. Even if I rev it up to 4500 rpm it will just bog... this problem just started and i'm not happy at all. It seems to have good power once I’m moving. If I get on it from a roll then it has good power. But if I rev it up and le the clutch out fast from a stand still it will die. I'm running an edlebrock carb. what should i do?
kman67rsss
10-05-2005, 08:54 AM
timing issue? detonation, wich could be timing related? not sure just throwing out some ideas.
cad
10-05-2005, 04:30 PM
check the spark plugs?
AFS
air fuel spark?
Really sounds like ignition...check that the distributor has not backed off. Happened to a brand new, expensive, shop-built 55 Chev running with us in Des Moines...everybody thought it was fuel...not me...I watch American Hotrod....every car that will not start with them is ignition timing.
joham22
10-09-2005, 11:29 PM
Fuel delivery, Fuel delivery, Fuel delivery!!! If carburated install JET EXTENSIONS. Change to a better fuel pump.....Summit has tech info on fuel delivery. I had the same problem until I changed the above.
