    Results 1 to 6 of 6
      New Orleans, La
      Drum spindle disk brakes with new suspension?
      I have updated My front brakes from drum to willwood 12" 4 piston setup. Will I still be able to use these brakes when I upgrade the suspension?
      I am looking at either a hotchkis or ride tech kit.
      My car is a 69 Camaro and I am still running the stock drum spindles.
      Houston, TX
      As long as the new suspension upgrades use the same spindle design, the brake set up will still work.
      Tu Ho
      Firebird V2-LS swap
      New Orleans, La
      Yeah, I would imagine the aftermarket spindles use a disk brake hub. Not sure if the conversion kit I have will work since it uses the factor drum brake spindle.
      Houston, TX
      Quote Originally Posted by Camaross82 View Post
      IIRC, the difference between the disc brake and drum spindles are the mounting holes for the brake components. Disc brake spindle has one mounting hole offset about 0.5". Your disc brake conversion kit probably had a spacer to account for the offset. The spindle pin is the same between drum and disc spindle.
      If you're unsure, check with ridetech or Hotchkis for their suggestions.
      Tu Ho
      Firebird V2-LS swap
      Jun 2009
      Tiffin Oh
      Will work fine with the ridetech spindles.
      Sep 2010
      Benicia, Ca.
      You should have no issues... The ridetech spindle is a great choice as it is 1.75" taller between the upper and lower ball joints which increases the camber gain during suspension compression (turns) which helps keep the tire leaning into the turn instead of out...
      The stock suspension leaves a lot to be desired but is easily fixed with the right parts!
      Matt
      MCB - Matt's Classic Bowties
      5360 Gateway Plaza Dr.
      Benicia, Ca. 94510
      866-628-8746
      TEXT ONLY: 925-989-9091 (Replied 8-4)
      www.mcbparts.com
      Email: [email protected]
      Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
      Hours: Monday to Friday 8am - 4pm Pacific
      We ALWAYS enjoy talking to our customers!
      We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
