83hurstguy
09-01-2014, 07:11 PM
I have a pair of Autometer Ultralite gauges, they are a 2-5/8" mechanical oil pressure and water temperature gauges (model 4421 and 4432), along with black steel gauge cups. Just took out of my car this weekend, I switched to 2-1/16" gauges because they fit better between my center console and radio. They both worked perfectly. I am including the brand new nylon line that came with my new oil pressure gauge, because I have a copper line installed. You'll need to get a new brass ferrule for the line (any hardware store will carry). There is some minor wear on the silver bezels and black cups. These sell for around $200 from Summit. I'm asking $100 obo for everything pictured, shipped to the lower 48.
Mac Tools flex head ratchet, 3/8" drive. Got a Snap On as a gift from the wife. Asking $30 shipped to the lower 48.
HRpartsnstuff rear sway bar brackets for a 2-5/8" axle tube (G-body, not sure what else), designed to clear brake lines on the axle so you don't have to bend the lines over a u-bolt. I bought them to run a pro-touring oriented sway bar (small diameter than the HRparts drag bar), but ended up re-doing my brake lines for disc brakes, so the regular u-bolts were a better solution. Brand new condition in original packaging (were opened to check fitment on axle at one point). Asking $85 shipped to the lower 48.
You can see a picture of them installed here (does not include the straps/bushings under the axle clamp): http://www.hrpartsandstuff.com/images/swaybar/DSC05284web.jpg
