MonzaRacer
09-01-2014, 07:20 AM
OK so this list will get updated as I find part numbers and Ill try to list at least on supplier or seller with it, These will be banjo bolts and banjo fittings brake washers, maybe even some bleeders, and if time and my patience holds tube nuts.
Banjo bolts and washers:
BrakeBest - Copper Washer
.450" I.D.
.675" O.D.
.032" Thickness
Part # : H9434
.450" I.D.
.675" O.D.
.032" Thickness
Part # : H9434-2
.405" I.D.
.675" O.D.
.051" Thickness
Part # : H9435
.455" I.D.
.625" O.D.
.060" Thickness
Part # :9436
.395" I.D.
.625" O.D.
.079" Thickness
Part # : H9437
Medium Duty Trucks: Top Kick/Kodiak/Hino
Part # : H9438
.595" I.D.
.800" O.D.
.032" Thickness
Part # : H9448
BrakeBest - Hose Inlet (Banjo) Bolt
General Motors
Size/Thread: 10MM (M10 X 1.5)
Length: 23.4MM
Use Copper Washer H9434
Thread Size: M10X1.50
Length (mm): 23.4mm
Part # : H9449-2
.510" I.D.
.800" O.D.
.030" Thickness
Part # : H9452-2
.390" I.D.
.625" O.D.
.062" Thickness
Part # : H9453-2
.450" I.D.
.800" O.D.
.064" Thickness
Part # : H9454-2
.540" I.D.
.695" O.D.
.032" Thickness
Part # : H9456
General Motors
Size/Thread: 7/16 Inch X 20
Length: .92 Inches
Thread Size: 7/16-20 Inch
Length (In): 0.92 Inch
Part # : H9457-2
General Motors
Length: 23.4MM
Use Copper Washer H9435
Length (mm): 23.4mm
Part # : H9458-2
Chrysler
Length: 1.09 Inches
Use Copper Washer H9436
Length (In): 1.09 Inch
Part # : H9459-2
.480" I.D.
.660" O.D.
.064" Thickness
Part # : H9461
Chrysler
Size/Thread: 11MM (M11 X 1.25)
Length: 23.88MM
Thread Size: M11X1.25
Length (mm): 23.8mm
Part # : H9468-2
Ford
Size/Thread: 11MM (M11 X 1.5)
Length: 24.9MM
Use Copper Washer H9437
Thread Size: M11X1.50
Length (mm): 24.9mm
Part # : H9469-2
Ford
Length: 27.17MM
Length (mm): 27.1mm
Part # : H9470-2
Ford
Size/Thread: 10MM (M10 X 1.00)
Length: 20.32MM
Thread Size: M10X1.0
Length (mm): 20.3mm
Part # : H9471-2
Ford Trucks
Size/Thread: 3/8 Inch X 24
Length: 1.03 Inches
Thread Size: 3/8-24 Inch
Length (In): 1.03 Inch
Part # : H9472-2
General Motors
Length: 27.32MM
Length (mm): 27.3mm
Part # : H9473-2
BrakeBest - Hose Inlet (Banjo) bolt
Audi/Volkswagen
Size/Thread: 12MM (M12 X 1.00)
Length: 21.33MM
Use Copper Washer H9461
Thread Size: M12X1.0
Length (mm): 21.33mm
Part # : H9476-2
Japanese Vehicles
Length: 23.37MM
Length (mm): 23.37mm
Part # : H9477-2
Ford
Length: 31.00MM
Use Copper Washer H9437, H9453
Length (mm): 31mm
Part # : H9478-2
Ford
Length: 31.25MM
Length (mm): 31.25mm
Part # : H9479-2
Dodge
Size/Thread: 10MM (M10 X 1.25)
Length: 24.13MM
Thread Size: M10X1.25
Length (mm): 24.13mm
Part # : H9486-2
Part # : H9487-2
.405" I.D.
.555" O.D.
.032" Thickness
Part # : H9489
.390" I.D.
.625" O.D.
.032" Thickness
Part # : H9493
Dorman Help! - Brake Banjo Bolt
General Motors
OE#: 15884703
Thread: M10-1.0
Length: 27.5mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Part # : 13912
General Motors
OE#: 487293
Thread: 7/16-20
Length: 7/8"
Hex: 7/16"
Head Size: 7/16 Inch
Head Type: Hex
Length (In): 7/8 Inch
Part # : 13935
Ford
OE#: N801052-S100
Thread: M10-1.5
Length: 24.4mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 24.4mm
Part # : 13936
Ford
OE#: N801363-S, N801363-S100, N802724-S, N802724-S100 & N802724-S150
Thread: M10-1.5
Length: 27.8mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 27.8mm
Part # : 13937
Chrysler
OE#: 6030026
Thread: 7/16-20
Length: 1-1/16 Inch
Hex: 5/8 Inch
Head Size: 5/8 Inch
Head Type: Hex
Length (In): 1-1/16 Inch
Part # : 13938
Chrysler
OE#: 6030230
Thread: 7/16-20
Length: 7/8"
Hex: 5/8"
Head Size: 5/8 Inch
Head Type: Hex
Part # : 13939
General Motors
OE#: 11518683, 11569669, 14000404, 14094948 & 88891786
Thread: M10-1.5
Length: 22.8mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 22.8mm
Part # : 13940
Ford
OE#: 385116-S2
Thread: 3/8 Inch-24
Length: 1-1/8 Inch
Hex: 9/16 Inch
Head Size: 9/16 Inch
Head Type: Hex
Length (In): 1-1/8 Inch
Part # : 13947
Russell - Banjo Bolt
3/8 Inch-24
Zinc Finish
Part # : 640650
3/8 Inch-24
Zinc Finish
Part # : 640660
7/16 Inch-20
Zinc Finish
Part # : 640670
10mm x 1.5
Zinc Finish
Part # : 640680
Mityvac - Banjo Adapter
MVA513 M8x1.0 Banjo Adapter - Toyota
Thread Size: M8X1.0
Part # : MVA513
MVA514 M10x1.0 Banjo Adapter - Toyota
Part # : MVA514
MVA515 M12x1.25 Banjo Adapter - Toyota, Lexus, Geo, Honda, Acura, Hyundai, Mazda, Daihatsu, Chrysler Imports
Thread Size: M12X1.25
Part # : MVA515
MVA516 M12x1.5 Banjo Adapter - Audi, Volkswagen
Thread Size: M12X1.50
Part # : MVA516
Jegs
555-100730
Banjo Fitting -3AN x 3/8" or 10mm
1/pkg
555-731
Banjo Fitting -3AN x 7/16" or 11mm
1/pkg
555-740
Banjo, Bolt & Crush Washer Kit -3AN x 3/8"-24
1/pkg
555-743
Banjo, Bolt & Crush Washer Kit -3AN x 7/16"-20
1/pkg
555-741
Banjo, Bolt & Crush Washer Kit -3AN x 7/16"-24
1/pkg
555-742
Banjo, Bolt & Crush Washer Kit -3AN x 10mm x 1.0
1/pkg
555-750
Brake Line Fitting Adapter -3AN to 1/8" NPT
Male to Male Straight
1/pkg
555-751
Male to Male 45°
1/pkg
555-752
Male to Male 90°
1/pkg
555-100760
AN to Inverted Flare Male Caliper Fittings
-3AN x 3/8"-24 Inverted Flare
2/pkg
555-100762
-3AN x 7/16"-20 Inverted Flare
2/pkg
555-100763
-3AN x 7/16"-24 Inverted Flare
2/pkg
555-100765
-3AN x 10mm x 1.0 Inverted Flare
2/pkg
555-100766
-3AN x 10mm x 1.25 Inverted Flare
2/pkg
555-100771
-3AN x 10mm x 1.5 Inverted Flare
2/pkg
555-100761
-4AN x 3/8"-24 Inverted Flare
2/pkg
555-100764
-4AN x 7/16"-24 Inverted Flare
2/pkg
555-100767
-4AN x 10mm x 1.0 Inverted Flare
2/pkg
555-100768
AN to Inverted Flare Male Caliper fitting
-4AN x 10mm x 1.25 Inverted Flare
2/pkg
555-100769
AN to Bubble Flare Male Caliper Fittings
-3AN x 10mm x 1.0
2/pkg
.450" I.D.
.675" O.D.
.032" Thickness
Part # : H9434
.450" I.D.
.675" O.D.
.032" Thickness
Part # : H9434-2
.405" I.D.
.675" O.D.
.051" Thickness
Part # : H9435
.455" I.D.
.625" O.D.
.060" Thickness
Part # :9436
.395" I.D.
.625" O.D.
.079" Thickness
Part # : H9437
Part # : H9438
.595" I.D.
.800" O.D.
.032" Thickness
Part # : H9448
General Motors
Length: 23.4MM
Length (mm): 23.4mm
Part # : H9449-2
.510" I.D.
.800" O.D.
.030" Thickness
Part # : H9452-2
.390" I.D.
.625" O.D.
.062" Thickness
Part # : H9453-2
.450" I.D.
.800" O.D.
.064" Thickness
Part # : H9454-2
.540" I.D.
.695" O.D.
.032" Thickness
Part # : H9456
General Motors
Length: .92 Inches
Part # : H9457-2
General Motors
Length: 23.4MM
Length (mm): 23.4mm
Part # : H9458-2
Chrysler
Length: 1.09 Inches
Part # : H9459-2
.480" I.D.
.660" O.D.
.064" Thickness
Part # : H9461
Chrysler
Length: 23.88MM
Length (mm): 23.8mm
Part # : H9468-2
Ford
Length: 24.9MM
Length (mm): 24.9mm
Part # : H9469-2
Ford
Length: 27.17MM
Length (mm): 27.1mm
Part # : H9470-2
Ford
Length: 20.32MM
Length (mm): 20.3mm
Part # : H9471-2
Ford Trucks
Length: 1.03 Inches
Part # : H9472-2
General Motors
Length: 27.32MM
Length (mm): 27.3mm
Part # : H9473-2
Audi/Volkswagen
Length: 21.33MM
Part # : H9476-2
Japanese Vehicles
Length: 23.37MM
Part # : H9477-2
Ford
Length: 31.00MM
Length (mm): 31mm
Part # : H9478-2
Ford
Length: 31.25MM
Part # : H9479-2
Dodge
Length: 24.13MM
Part # : H9486-2
Part # : H9487-2
.405" I.D.
.555" O.D.
.032" Thickness
Part # : H9489
.390" I.D.
.625" O.D.
.032" Thickness
Part # : H9493
General Motors
OE#: 15884703
Thread: M10-1.0
Length: 27.5mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Part # : 13912
General Motors
OE#: 487293
Thread: 7/16-20
Length: 7/8"
Hex: 7/16"
Head Type: Hex
Part # : 13935
Ford
OE#: N801052-S100
Thread: M10-1.5
Length: 24.4mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 24.4mm
Part # : 13936
Ford
Thread: M10-1.5
Length: 27.8mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 27.8mm
Part # : 13937
Chrysler
OE#: 6030026
Thread: 7/16-20
Length: 1-1/16 Inch
Hex: 5/8 Inch
Head Size: 5/8 Inch
Head Type: Hex
Part # : 13938
Chrysler
OE#: 6030230
Thread: 7/16-20
Length: 7/8"
Hex: 5/8"
Head Size: 5/8 Inch
Head Type: Hex
Part # : 13939
General Motors
Thread: M10-1.5
Length: 22.8mm
Hex: 11mm
Head Size: 11mm
Head Type: Hex
Length (mm): 22.8mm
Part # : 13940
Ford
OE#: 385116-S2
Thread: 3/8 Inch-24
Length: 1-1/8 Inch
Hex: 9/16 Inch
Head Type: Hex
Part # : 13947
3/8 Inch-24
Zinc Finish
Part # : 640650
3/8 Inch-24
Zinc Finish
Part # : 640660
7/16 Inch-20
Zinc Finish
Part # : 640670
10mm x 1.5
Zinc Finish
Part # : 640680
Thread Size: M8X1.0
Part # : MVA513
Part # : MVA514
Part # : MVA515
Part # : MVA516
Jegs
555-100730
1/pkg
555-731
1/pkg
555-740
1/pkg
555-743
1/pkg
555-741
1/pkg
555-742
1/pkg
555-750
1/pkg
555-751
Male to Male 45°
1/pkg
555-752
Male to Male 90°
1/pkg
555-100760
2/pkg
555-100762
2/pkg
555-100763
2/pkg
555-100765
2/pkg
555-100766
2/pkg
555-100771
2/pkg
555-100761
2/pkg
555-100764
2/pkg
555-100767
2/pkg
555-100768
2/pkg
555-100769
-3AN x 10mm x 1.0
2/pkg
