mrk
08-25-2014, 09:47 PM
Lingenfelter LS9 2010 Camaro SS drag car specifications
Engine
o 427 CID/7.0L Gen IV GM V8 engine
LSX iron block
LPE ported LS9-LSX 6 bolt cylinder heads with OEM LS9 titanium intake valves and LS9 sodium filled hollow stem exhaust valves
ARP head studs
JE forged pistons (2618 alloy)
9.5:1 compression ratio
Callies Ultra Billet 4.000” stroke crankshaft
Oliver 6.125” connecting rods
Lingenfelter GT9 camshaft
Comp Cams 26918 valve springs with stock retainers
Stock LS9 oil pump
o GM LS9 Eaton TVS2300 supercharger
o Lingenfelter high-flow LS9 supercharger front cover
ported to accept 102 mm throttle body
o Lingenfelter custom fabricated double stacked LS9 intercooler upper manifold
o LS9 Corvette accessory drive
o LS9 dry sump oiling system with custom front mounted dry sump tank
o Lingenfelter LS9 14% overdrive damper kit
o 102 mm billet throttle body
o Lingenfelter 2.38” supercharger pulley
o Lingenfelter 160 thermostat
o American Racing 2” primary headers
Two stage dry nitrous system with NCC-002 progressive nitrous controller
Lingenfelter Camaro SS twin pump fuel system, mechanical regulator version
o 20 volt Dual Boost-A-Pump fuel pump voltage booster
o Vacuum/boost referenced Weldon fuel pressure regulator
All fuel supplied to the engine is delivered by the in-tank Lingenfelter twin fuel pump system and the eight (8) primary Bosch Motorsports injectors in the LS9 manifold
o No auxiliary fuel system
LNC-003 2-step controller
7 LED shift light
RPM transmissions prepared Turbo 400 transmission with manual valve body
Lingenfelter/AAM 9.5” differential case with 4.10:1 ring and pinion
Heavy duty Driveshaft Shop halfshafts
Custom driveshaft
BMR driveshaft loop
GM V6 Camaro brakes front and rear
SJM line lock
LPE TVS diodes on line lock and nitrous solenoids
Tubular front K-member
Lingenfelter adjustable rear trailing arms
Lingenfelter adjustable rear tie rods
Lingenfelter adjustable rear stabilizer bar end links
Lingenfelter/Pedder’s double adjustable front and rear shocks with drag race springs
Hotchkis Chassis Max subframe brace
Front sway bar removed
Hotchkis rear anti-sway bar
Solid subframe bushings
Custom fabricated Delrin differential bushings
o LPE slotted high rise hood
Prototype Lingenfelter Camaro gauge pod with Auto Meter memory boost gauge
Kirkey racing seat with custom fabricated seat rails (still functioning power seat)
Rear mounted high capacity intercooler reservoir
Stewart-EMP WP29 high flow DC brushless intercooler fluid pump
o Bogart 16 x 4.5 front wheels with M&H 4.5/27-16 front runner tires
o CCW 16 x 10 rear wheels with M&H 12.00-16 Racemaster tires with tubes
NHRA legal 10 point roll cage, certified to 8.50
NHRA legal parachute
Functioning (and stock) air conditioning
Best quarter mile when manual transmission 6.2L LS9 equipped:
o 8.997 seconds at 158.80 mph (21 November 2010 at MIR)
Best quarter mile ET when automatic 427 CID LSX equipped:
o 8.789 at 164.98 mph at Muncie Drahway on 10 October 2012
700 hp & 800 lb-ft of torque at the rear wheels on supercharger only with fairly rich/slightly low spark calibration normally used for 1st stage of nitrous (thru AT trans)
$75k
pm for phone number
1230 hp & 1080 lb-ft of torque at the rear wheels on nitrous (thru AT trans)https://www.pro-touring.com/attachment.php?attachmentid=102043&stc=1https://www.pro-touring.com/attachment.php?attachmentid=102044&stc=1https://www.pro-touring.com/attachment.php?attachmentid=102045&stc=1
Engine
LSX iron block
ARP head studs
Stock LS9 oil pump
7 LED shift light
Custom driveshaft
BMR driveshaft loop
SJM line lock
$75k
pm for phone number
