View Full Version : dana 60 rear differential squeaking?
StandardRS
08-14-2014, 03:59 PM
Ok so the rear differential is a dana 60 with dutchman axles. I am unsure what lsd is in it. So I have drove the car a total of 10 miles maybe. A light squeel is coming from the pinon area. Parts are all new. No play what so ever. I have used 75w90 no lsd additive. ? Iam at a loss any info would be great! Would not using the additive cause this?
bryant
08-15-2014, 09:53 PM
if no lsd additive was the problem it would only make a groaning or chattering noise when turning.
squealing from the pinion area is usually a dry u joint. their is a small chance that the pinion seal may be squealing on the yoke but doubtful.
08-16-2014, 07:16 AM
you can try to lube the seal and see if it goes away.
If you have access to a lift hoist you can run it up on the rack and use an automotive stethescope or heater hose to your ear to pin point the noise.
StandardRS
08-22-2014, 08:39 PM
So it was either the seal or the front pinion bearing. Figured I would try those before tearing it all apart. And its fixed!
