Fbomb1971
08-12-2014, 06:30 PM
Hello all, for sale is a complete bottom end kit for a small block Chevrolet, This includes brand new Callies Compstar crank (professionally balanced for the rods and pistons), new Callies Compstar rods with ARP fasteners still in original plastic, new CP Bullet series pistons with wrist pins and rings, and new ACL race series rod and main bearings still in original plastic. All of these parts were purchased brand new in 2012 with the intentions of building a high horsepower, high winding 358 small block, but I have sense moved on from that project and hate to see such high quality parts just sit around, so my loss will be your gain. Below I will give a detailed list of part numbers and specifications, along with original prices (totaling $2500) so you can see how much money has been invested into these parts, and the significant saving you will receive when buying these parts. This setup will give you every part you need to build an incredibly strong, high horsepower small block, and will be a true “bolt in” setup (350 block). Please feel free to contact me with any questions you may have.
Crank-
· Callies Compstar part# SAF-113-cm ($826)
· 3.480 stroke with a 2.100 pin size
· Has been professionally balanced to weight of rods and pistons
· Brand new in original packaging.
· Can be seen here http://www.callies.com/compstar/crankshafts/compstar-small-block-chevy/
Rods-
· 5.700/2.100 H beam rods ($667)
· 606 grams
· ARP fasteners
· Brand new, new taken out of original sealed packaging
· Can be seen here http://www.callies.com/compstar/connecting-rods/h-beam/
Pistons-
· Cp “bullet series” BC1021-030 ($670)
· 4.030 bore, flat top w/ 2 valve reliefs
· Include piston rings set
· Can be seen here http://www.summitracing.com/parts/cnn-bc1021-030-8
Wrist Pins-
· CP Pistons 927-2500-15CP1C ($172)
· Fully coated, Chromoly wrist pin
· Chamfered, hardened, and gun frilled
· Can be seen here http://www.frsport.com/Stock-Coated-Pin-Length--2500mm-Material--Chromoly-Type--Chamfered-_p_214081.html
Bearings-
· ACL Bearings 5M909H-STD Race Series Race Series Mains ($61)
· ACL 6B2630H-STD Race Series Rod Bearing Set ($75)
· These ACL bearings are high quality race ready bearings manufactured with a tri-layer metal with a hardened steel backing in order to withstand high RPM conditions, high stress loads, and high temperatures.
Here is the link to the ebay auction, Thanks
http://www.ebay.com/itm/291214440496?item=291214440496&viewitem=&vxp=mtr
101241
Crank-
Rods-
· 606 grams
· ARP fasteners
Pistons-
Wrist Pins-
Bearings-
101241
