View Full Version : G-body rear sway bar, billet water pump pulley, Olds starter, steering shaft
83hurstguy
08-07-2014, 07:41 PM
RobbMc Olds starter, new but used for fit up purposes. Info here: http://www.robbmcperformance.com/products/olds_starter.html
Comes in a powermaster box, won't clear my headers. $210 obo shipped to the lower 48.
Hellwig 55809 rear sway bar for G-body. Brand new, used for fit up, I ended up switching to a Detroit Speed bar. It won't clear a G-body 8.5" rear end with LPW aluminum support cover. Should be fine on all 7.5" rears or 8.5" with stock cover. Some of the paint on the end links is scratched, it came that way from Hellwig. The ends come like 7" long, I trimmed them to length already (saving you the hassle), and I also included some 3/8" thick aluminum spacers I fabricated and plastidipped to lower the bar slightly in an attempt to make it fit with my LPW cover. Asking $170 obo shipped to the lower 48.
https://static1.pt-content.com/images/pt/2014/08/hellwig1-1.jpg
https://static1.pt-content.com/images/pt/2014/08/hellwig2-1.jpg
This is a long shot here, but it's a March billet aluminum pulley (model 4312) for use with Chevy truck serpentine setup (4.3/5.0/5.7). May work with cars too, can supply measurements if interested. Brand new, has a few minor scratches/scuffs from testing fit up. Asking $40 shipped to the lower 48.
Last, I have a Jeep steering shaft that works as a retrofit on a G-body to replace the stock steering shaft. I bought this from a person selling them to forum members after finding/cleaning/painting them, and it worked fine on my car. The problem with it was that when changing the length, the person removed the plastic insert that went inside the collapsible portion of the steering shaft, which leads to a very minute amount of slop in the steering wheel over center (so I switched to a DSE shaft). U-joints are in great shape, comes with the upper and lower bolts as well. If you fill the shaft gap with something or put a shear pin in that would break in an accident, it would be perfect. Asking $20 shipped to the lower 48.
83hurstguy
08-12-2014, 05:43 AM
Hellwig sway bar sold, steering shaft pending. Thanks!
83hurstguy
08-19-2014, 10:01 AM
RobbMc starter sold.
