strangler
09-26-2005, 05:17 AM
My 396 has destroyed 3 cams in >5000 miles. I dont know why. Buildup:
69 396 block and crank
12:1 (with 106cc) forged pistons
Dimple rods
781 heads with new seals, seats, 3 angle etc.
120lb seat pressure springs
diamond racing pushrods
harland sharp roller rockers
manley rocker studs and guideplates
holley dual plane
edelbrock 750
MSD ready-to-run
cams have been:
Mild hyd flat tappet .500 lift - first lobe to dissapear, and lifters worn through. Stock rockers were used at the time, so I thought they were binding and replaced them with the roller rockers.
Then I installed another mild hydraulic (roughly .510)- along with new lifters and the new rockers it was installed after flushing out the motor. It lasted about 10 minutes before the stock replacement pushrods turned into wet noodles, and broke the pressed in ends off of them. The cam was also scratched so it was replaced with the next one
Installled a solid L-88 replacement (.560/.580)- Installed this cam with new solid lifters, roller rockers, and the new diamond racing pushrods. Cam worked fine with no damage to any of the parts, but the cam made no power with my combination, so it came out last week to be replaced again- starting to understand my frustration?
OK, last week I installed a Comp Cams .595/ 294s cam and new lifters. Inside of engine was still clean and lifters slid right into bores with no problems. Comp asked for .022 hot for a lash, so I lashed the rockers cold at .024, started it up with fresh oil, and ran it at 2500-3200 for 15 minutes or so- having good oil pressure. Yesterday I started it up again and drove it around the block to warm it up, came home and drained the oil, and removed the valve covers to re-lash the now-hot rockers. They were all about .001 loose, so I went through and re-set them all to the .022 that Comp asked for.... nothing funny, they were all within .002 So I decided to drive it to my Dads house 40 miles away to further break it in, and ask his advice on some carb issues Id been having. By the time I got off the highway (after running about 2900rpm) the motor was feeling fairly dead, like it was running really rich, yet without the smoke, and now it was popping through the intake. Removed valve comes again and foung #6 intake to be dead, not so much as a 1/8" of movement. Any ideas before I scrap this whole POS and build a different engine? My Dads convinced the valve springs are too stiff, but I selected this last cam with those springs in mind, being exactly what Comp would reccomend. Thanks for any advice.
454 short block wanted......
Dimple rods
holley dual plane
edelbrock 750
MSD ready-to-run
cams have been:
