View Full Version : Will G8 6.0 (L76) complete motor with accesories.....
cpd004
08-04-2014, 01:25 PM
and it's 6L80e fit in my 71 Firebird? I know most people go with the accessory drive from an F body, but will the G8 stuff work without notching the frame? I assume the trans won't be an issue, but I'm here for advice.
I have a line on an a complete L76 w/ 6L80e from a G8 and want to swap it into my 71 Firebird. I just want to know if I'm ok with this combo other than motor mounts, fuel supply, exhaust, etc.
https://static1.pt-content.com/images/pt/2014/08/0820L7620G81-1.jpg
Schwartz Performance
08-04-2014, 02:26 PM
You'll need to swap the oil pan to an Fbody style or Holley. The Trans tunnel will probably need to be modified as the 6L is very big. Not 100% sure on the extent but it's a big trans.
The Fbody accessories I can't comment on either sorry.
-Dale
cpd004
08-04-2014, 06:01 PM
The other option I was offered is an 06 GTO ls2 with 4l60e. This may be a better option as I shouldn't have to do any tunnel work, correct?
08-04-2014, 06:10 PM
Correct. But you'll still need to swap the oil pan.
-Dale
BonzoHansen
08-04-2014, 07:17 PM
That six speed auto will hang low too.
cpd004
08-05-2014, 04:11 AM
Thanks for the replies guys! Figures about the trans. When getting the GTO motor/trans, will those accessories work in an f body or will I still need to source the 98-02 stuff?
dhutton
08-05-2014, 08:37 AM
http://ls1tech.com/forums/conversions-hybrids/898899-6l80-6l90-into-68-camaro-does-go.html
Don
