View Full Version : First Gen Camaro Exhaust with a minitub and T56
lftnwhls
07-27-2014, 05:15 PM
Does anyone out there have an exhaust kit that works on a first gen Camaro with a T56 and a DSE Minitub. I bought a Magnaflow kit but it was for a stock car and by the time a modify it I might as well start again.
Z06vet
07-28-2014, 11:35 AM
Are you running 4 link or leaf springs? Either way you are likely going to have a shop make some tailipies for you. Everything from the kit should fit but the tailpipes. I usually buy mufflers & the X pipe, then have the shop bend up the rest. I chose to run my tailpipes under the axle but a good shop should be able to run them over the axle for you.
Genros
10-09-2014, 04:22 PM
I'm running the heists four link and can't fit anything between the axle and panhard bar. Any help would be appreciated
Genros
10-09-2014, 04:23 PM
Heidts
jethrow6978
11-13-2014, 12:15 PM
You can have a shop install custom tailpiping for it. They will have to go over the rear and under the panhard bar and then travel on out. Its very time consuming and a big P.I.T.A. But do-able. Most just run dumps right in front of the rear because its cheaper and easier. Here is a link to show how this would go. https://www.youtube.com/watch?v=mncjKxHu7j4
dragonfly jones
11-13-2014, 05:47 PM
Very good video. Thanks for sharing.
Motown 454
11-14-2014, 07:11 PM
V8 TV does some sweet Fab work.
