Carl @ Chassisworks
07-23-2014, 03:15 PM
Designed as the ultimate upgrade for top tier pro-touring performance, the new gStreet spindle provides vastly improved geometry, bearings, and brakes for all Chassisworks’ bolt-on front clips.
Use of this spindle requires Chassisworks new gStreet Wide-Track control arms which provide more gradual geometry changes throughout suspension travel for more direct tire feedback and more linear response to steering and braking inputs under various dynamic conditions.
Specific geometry changes include vastly reduced scrub radius, improved camber gain, and increased caster (8.5 degrees at center of adjustment) without altering the wheelbase. The lightweight upright houses a heavy-duty, sealed unit bearing that is both larger in diameter and considerably more reliable than the commonly used Corvette components.
Completing the gStreet system is the large diameter brake package built around Wilwood Engineering’s race-bred Aero6, 6-piston, radial-mount caliper with 14” or 15” vented rotors
Check out this link for a massive amount of technical info and more pictures! https://www.cachassisworks.com/Attachments/DataSheets/5737-XXX_DS_WEB.pdf
https://static1.pt-content.com/images/pt/2014/07/5737sm12_1_-1.jpg
https://static1.pt-content.com/images/pt/2014/07/5737sm12_6_-1.jpg
https://static1.pt-content.com/images/pt/2014/07/5737sm12_5_-1.jpg
