    Results 1 to 5 of 5
      Jul 2014
      Brisbane, Australia
      Country Flag: Australia
      Using curved tubular arms to lower the suspension?
      Hi guys, I have an unusual problem.
      My project uses double a arm suspension identical to the Pontiac Fiero and Chevrolet Chevette, I have been planning to build a new cross member and suspension arms to convert it to coilover and raise the suspension arm mounting points in order to give the suspension a 2" drop without negatively affecting the suspension geometry.
      The problem I'm having is that the bushes on the lower arms are offset from eachother, and normally it wouldn't bother me but the rear mounting points for the lower arms are right underneath the chassis rails where the chassis meets the firewall.
      now these cars are a unibody and the chassis is essentially a pressed section of steel welded to a flat sheet, so I know that the transport body over here won't allow me to cut into it.
      Is it possible of even or even ideal to make a set of arms that radius upwards enough to hold the spindle 2" higher than the stock arms? would this affect the geometry?
      As far as I can tell, but I'm not too familiar so I'm not sure, the curve in the arms would pull the spindle inwards more than usual during compression stroke, am I right in thinking this?
      Can anyone offer me any suggestions?
