View Full Version : Looking for IRS/IFS for 1st gen
spookypilot
09-11-2004, 05:48 AM
Any have sights or info on replacing 1st gen (69)suspension with IFS/IRS from corvette C4/C5?
TitoJones
09-11-2004, 06:31 AM
What info do you need?
I am doing a 67 with this in the front:
https://www.pro-touring.com/~tylerb/WD2.jpg
And this in the rear:
https://www.pro-touring.com/~tylerb/WD1.jpg
Tyler
spookypilot
09-11-2004, 06:42 AM
Just wondering if they are companies out there producing IFS/IRS parts for 1st gen. So far they only place I have found is a place in alabama called Street Shop Chassis Work. (http://www.streetshopinc.com/products.htm)
Was hopping to find someone producing 'kits' using C4/C5 suspension components. Seems like a lot of work being done by companies for Tri-5 chevys but not for the f-body.
camcojb
09-11-2004, 07:01 AM
The guy who built the above for Tyler has kits to put the Vette stuff front and rear on the 67-69 Camaros. Here's his website:
Wayne Due (http://www.waynedue.com/)
Jody
68ls1
09-13-2004, 12:02 PM
Or if all else fails you can tackle it yourself! Thats what I did with my IRS. No matter how you look at it installing an IRS is no bolt in deal, a kit will help but there is still welding and alignment to be done by the installer (you). I've never frabricated so much as a bracket until I installed mine. Time and patience are all thats required. Plus you'll save yourself a #@$% pile of money!
Chill, Noel.
mikesz
09-13-2004, 04:45 PM
Chill, Noel.
Where did you get your measurements from to start with?
mike
68ls1
09-19-2004, 10:12 AM
I had no measurements when I started, I just realised that I had payed for an irs and I had better make it fit. I have some new pics of the completed install, I should be able to post them soon. I'm just on my way back to work for another month but I could get you measurements when I get home. As far as placement was concerned I just made sure the rear was square and true, I will have to get a custom driveshaft anyway.
Let me know if you would like to see the pics and I can start a new post.
Chill, Noel.
