View Full Version : 1 Gen Camaro Schwartz Extreme Chassis Complete Pro Touring
tombar67
07-18-2014, 02:43 PM
SOLD SOLD SOLD
I have up for sale a Schwartz Extreme Chassis for a first generation Camaro. This is a full Pro-Touring frame that replaces the factory sub frame. Everything pictured is included. Below is the spec list. Price is SOLD
- A fully welded chassis, built on a precision jig
- Adjustable transmission crossmember
- Race-bred front and rear suspension components control arms, ball joints, tie rods, power rack & pinion, aluminum front wheel hubs with bearings, and teflon-lined heim joints for a quieter & bind-free suspension
- 14" front rotors with Wilwood 6 piston calipers
- 13" rear rotors with Wilwood 4 piston calipers
- QA1 Coilovers
- Kinesis Wheels the rears are 19x14.5 with 8.5 back spacing with 345/30/19 Michelin pilot sport radial x's. The fronts are 18x10 with 275/35/18 Michelin pilot sport radial x's.
- Stainless brake lines already bent to frame (rears not pictured)
- Sweet Manufacturing power steering rack with integral servo with braided lines
- Splined front and rear sway bar shafts
- Front end was widened 1" on each side from stock strong arm lower control arms tubular upper control arms with threaded ball joints
- Rear end is a moser ford 9" with circle track style hubs with back brace has nodular case with 3:55 posi and moser axles and has been narrowed 1" from stock
- Triangulated 4-link rear suspension with QA1 polished heims
- Chassis was modified to work with air ride or QA1 coilovers
- Chassis motor mounts are set up for LS style engine.
- There were some modifications done to the front end to increase the turning radius. Also some changes were done to the rear 4-link and front suspension to be able to adjust to a lower ride height if need be.
99813
99814
99815
99816
99817
99818
tombar67
07-21-2014, 08:22 AM
Bump
KHShapiro
07-21-2014, 06:59 PM
Kinda awesome not gonna lie.
tombar67
07-21-2014, 07:19 PM
Thank you. Hopefully someone can finish it.
cwylie
07-22-2014, 05:58 AM
Man this would have made all the work I just did so much easier than buying all the parts, measuring, fitting and welding. To be honest it would have probably been about the same price as well and I still have the stock front sub frame. I know 20k seems like a lot but really you cant do anything close to this type of quality for the same price.
31069ss
07-22-2014, 06:07 AM
This is straight baller stuff right here .... If i had the money i would jump all over this ! glws
tombar67
07-22-2014, 06:58 PM
Thanks for the appreciation guys.
tombar67
07-28-2014, 09:02 AM
Bump
minendrews68
07-28-2014, 07:11 PM
What I'm sayin'... !!! :yum:
tombar67
08-01-2014, 03:55 PM
Bump
tombar67
08-14-2014, 04:23 PM
Bump
Blue89Bird
08-15-2014, 04:52 AM
really wish I had the money for something like this. It's almost too pretty to slap a body on.
tombar67
08-26-2014, 03:31 PM
Sold
