View Full Version : pro touring setup- HELP NEEDED!!
hogpowr
06-22-2014, 03:09 PM
Guys, I've been to a few ultima battery challenges and I've finally decided to get my car ready for it. Its 50% there. But I need help on the "right" setup for my car. I have a 70 challenger. I've already put tremec 5 speed with upgraded syncros in it. I'm running 215 front tires and 335 rear tires. It has 3.90 power lock rearend and a 500HP big block in it. I am running firm feel front sway bar on large road race tortion bars and original leaf spring rear end. The car is all steel. I have a bolted in main hoop and frame connectors. 13" wilwood brakes on drum spindles in the front and cheapo metric GM rear disks. so what should I do and in what order. put car on diet? coil overs on rear? coil over and new front stub/k member up front? I don't want to spend for the sake of spending, but I want to be competitive.
I need advice and help guys. I"m willing to spend $$ to get this done right and I'm comfortable with fabrication work. I'm being serious. I really need good advice on where to spend money next. My guess is... put good rear brakes on, good pads, make sure my front rotors can handle it and put pan hard bar on
rear.. but again I"m guessing.
.....97940
J-440
06-22-2014, 04:33 PM
Well I would upgrade the suspension first. Lose the torsion bars, leafsprings, and the drum brakes. By getting coilovers all around and an aftermarket front end, you can add wider tires front and rear. Also a 4 link is your best bet for a rear suspension. The tubular front end will lighten your car and have more oilpan and header clearance. After that there are more mods you can do but this will give you a start.
J-440
06-22-2014, 04:35 PM
Oh, and get those frame connectors and main hoop welded in.
hogpowr
06-22-2014, 06:29 PM
frame connector is welded in, I'm already running 4 wheel disk brakes and have tubbed the rear, so I have 335 series rear tires on it now. I love the idea of coil overs no doubt a huge improvement. What about a full hotchkis setup? I can spend $3-4000 and buy everything hotchkis as for the challenger and keep tortion bars & leaf springs or 15k for front and rear coil overs. Is the extra $10-12,000 that noticable?
benno505
06-22-2014, 07:23 PM
alot of guys swear by the hotchkis stuff, i run a magnunmforce tube fron tand 4 link rear in my charger, i alsio think j-440 runs the same. i do not know how they compare to the hotchkis stuff. but i love the way mine handles. if you got the power might as well start lightening it up and better suspension/brakes would by my advice too
Bonehead
06-22-2014, 07:27 PM
Beautiful challenger!
no go nova
06-22-2014, 07:35 PM
I say what ever gets you wider tires on the front. I think the 215 vs 335 is no a close match. the rear tires prob push the fronts while your turning in. Just my guess. Sweet ride tho.
hogpowr
06-23-2014, 04:41 AM
to this point I haven't cornered it aggressively, but I assume it will be a push monster. I think I can get a little bit wider tire up front with some backspacing, but not too much more. thanks benno505. I've looked at the magnum force stuff. they are definitely in the running. good to know you are happy with it. did magnum force give you ideas on shock values / spring rates when you bought it?
sccacuda
06-23-2014, 05:06 AM
Nice Challenger! I would give Hotchkis a call and discuss your plans. They seem to have really dialed in the E-Body using the stock mounts.
They had a "pro" driver in the car and it ran with all the big dogs on lap times.
That 215 is not going to handle too much braking force up front, so a pad upgrade may just do the trick. You CAN fit a 275 up front with the right back space. Check the Cuda-Challenger forum for specifics on wheel offset.
DTM Racing
06-23-2014, 05:08 AM
We just helped a customer with his Cuda that had a tubular front end kit, and unfortunately they have no where near the adjustability of the Hotchkis setup and offer no more room for a larger tire. They actually offer less articulation and adjustment as they try to create space around the coil. After giving the customer a ride in a Full Hotchkis equipped car, he said if he could do it all over again, he'd have gone with the Hotchkis. The level of adjustability and tuning is outstanding. Unfortunately the shop that did the install on his car had welded the link system into the back of the car (which has had it's own set of issues) and so it's pretty unreasonable to go back. You should look in to something in the 275 for a front tire, the 335 rear is quite a bit of steamroller, you may want to look into downsizing it in to a better aspect with the front for more favorable handling.
LemonTwisted
06-23-2014, 05:23 AM
I'd take a serious look at the Hotchkis platform first. Complete bolt on and you can be up and going in a weekend. You can also try it out before you buy it by doing a ride along in their E Max Challenger, looks like it'll be at Chryslers at Carlisle (http://carlisleevents.com/carlisle-events/carlisle-chrysler-nationals/carlisle-chrysler-nationals-detail.aspx?detailid=546) in July.
benno505
06-23-2014, 02:30 PM
they first sent me 450lb front springs and 170 lb rear springs they turned out to be too soft as i am still running a 440(505) wedge with ally heads. so they upped them to 500lb fronts and 200 lb rears.
I just tuned to what felt right for me.
benno505
06-23-2014, 02:33 PM
like previous comments i would look into hotchkis. the tubular kit from magnumforce ahs the most adjustability out of any other kit, but unless you have patience it takes along time to tune it in.
hogpowr
06-23-2014, 06:43 PM
thanks guys. Benno505. thanks for shock info. Mine 500 cube big block with aluminum heads as well. I built the car for the "look". but now I really do want the thing to handle. for the price, I'm having a hard time spending a bunch more for coil overs. If someone said, here are all the benefits...... I would consider it. But seems like hotchkis can get me there. Put the car on a serious diet and get right shock / spring rates, it may be every bit as fast as the higher priced setups. all advice is appreciated. thanks guys. keep any other suggestions coming! I would love more pros / cons on hotchkis setup vs full coil over setup.
hogpowr
06-23-2014, 06:46 PM
guys. with tortion bar front end. can anyone give me approximate back spacing to get 275 front tires on it. I am running 17" wheels now, but kind of like 18s the more I see them.
DTM Racing
06-24-2014, 05:20 AM
Every car is different. I never give folks backspace numbers because if you go buy 1500-2500 worth of front rims and they don't fit, I'd feel pretty bad.
struck by Lightning
06-24-2014, 07:38 AM
+1 on the Hotchkis kit. Also, join your local SCCA and get as much seat time as possible.
hogpowr
06-25-2014, 11:08 AM
I think I've decided to do some hotchkis stuff and firm feel. going to stick with tortion bars and leaf springs. but going to have stuff specifically built for track days. any recommendations or ideas on shock weights front and rear and leaf spring pounds I would appreciate it.
DTM Racing
06-25-2014, 04:17 PM
Hotchkis Kit is all sorted out for rates and valving.
Riddler
06-25-2014, 06:14 PM
I went with Reilly Motorsports AlterKtion front and and Streetlinx rear. Take a look at their setup and see if it'll work for you.
Riddler
DTM Racing
06-25-2014, 06:52 PM
Riddler
Great setup for a show car or drag racing. Terrible for any motorsport where cornering is involved.
sccacuda
06-26-2014, 05:19 AM
Take a look at QA1's K-frame as well.
hogpowr
06-26-2014, 12:26 PM
thanks guys. anyone running leaf springs in the rear that can give me some spring rates they are using? Sounds like 200lbs springs for road racing is the ballpark. again my car is mostly all steel. (fiberglass hood and bumpers)
hogpowr
06-30-2014, 06:39 PM
hotchkis recommends 160lb rear leafs. firm feel says 200lb leafs. anyone have a thought on the two?
DTM Racing
07-01-2014, 05:27 AM
Hotchkis uses sway bars and shocks to control the car, Firm feel uses a softer shock and sway bar with a stiffer spring.
OG_Racing
07-01-2014, 06:43 AM
I agree 100%. I would run a minimum of a 275 up front. All your weight of the big block you're going to need a lot more tire to turn and stop it.
High Plains Mopars
07-01-2014, 08:34 AM
Nothing like starting in the top rung of competition right out of the gate. Most of the Optima events tend to be populated by some of the best PT style cars and some of the better drivers around. If you haven't turned a corner in anger on a road or autocross course previously, you are going to be at a significant disadvantage right out of the gate, even with a very well set up car.
All that aside, no, you don't need to go to a coil over conversion to have a good handling car. You can make a significant improvement with the stock stuff as a lot of the Mopar geometry is much better in OEM form than the same era Chevy and Ford stuff. The two biggest issues with the OEM Mopar system is bump steer and the lack of torsion bar selection. The Mopar torsion bar in your Challenger is only available in 1.0, 1.06, 1.12, 1.18, and a special order 1.24 rate. The physical size of the anchors means you can't get anything bigger than 124 in a t-bar. That limits your wheel rates to something between 175 to 425#. That is the equivalent of a 400-850# coil spring range in a Camaro. So the Mopar has 5 choices where the Camaro will have 10 choices in 50# increments to chose from to optimize the spring rate. As such, you need to spec out the t-bar first, then back into the proper leaf rate to balance the car against your selected sway bar choices. IE, with a large rear sway bar, you leaf spring choice could drop down to the 120# range.
There is a '69 Charger that has participated in some of these events on the stock set up and has done reasonably well. He does post on here, but I don't recall his user name. However, if you plan on winning these events, you may eventually have to go to a conversion suspension to be able to quickly dial in the required rates and to loose additional weight to help speed up your car.
First, I'd step up your front tire size. 215 isn't much better than a drag race tire. Then decide on a course of action for the suspension. As mentioned, Hotchkis tends to use softer spring rates with higher roll rates and shocks that are dialed in to support these rates in a complimentary fashion. Old school autocross approaches tended to use much higher spring rates and roll rates with more basic shocks. So, I'd say it all comes down to your shock budget. How much are you willing to spend here and you can decide on how to spring the car.
The Hotchkis package is a nice, dynamically tested package of parts that are proven to work well together without compromising street capability. If you want to chase a more track oriented set up, then you will want higher spring rates than the Hotchkis package recommends and that means you will need to step up to complimentary rate shocks This could mean some high end adjustables or some specially valved units built specifically for your application.
I believe the Hotchkis Challenger is using 1.06 t-bars and 160# leaf springs. By contrast, some autocross Mopars are using 1.24 t-bars and 200# leafs. Also, keep in mind that overall weight of the car will impact the effectiveness of these rates. Since Mopars are so limited in t-bar rates, weight loss in the only way to improve the effectiveness of these limited rates available.
So you can make the stock stuff very effective for somewhere between $3-6 grand, depending on shock selection. I'd venture a guess that this type of suspension will be able to handle the driving capability of 90+% of the drivers out there. Whether or not the $10-12k cost of a conversion suspension is worth it is really dependent upon your ability and your seriousness of the effort you want to put into competition. Obviously the Optima series have very limited rule constraints about suspension set up, so you may be looking at entering a spending war to be in the top tier of competition with these guys. This spending could come through actual hardware upgrades or driving schools to improve the nut behind the wheel. How bad do you want to win?
hogpowr
07-01-2014, 08:59 PM
thanks high plains. awesome input. I currently have a firmfeel 1.06 tortion bar and sway bar up front and have left back half pretty stock. that is going to change this winter. decisions, decisions. I know this...... the car is going on a serious diet this winter. have to see how much lighter fiberglass fenders are than steel. going to do bumpers and deck lid for sure. already have a glass hood. keep the input coming!
benno505
07-02-2014, 04:45 PM
i believe a 275 will fit in the challenger front wheel well with the correct backspacing which i do not know.
with some slight rubbing.
bigger tyres, better brakes, lighten the car up.
magnumforce suspension also drastically reduces your overall weight also and gives really good clearance for everything
hogpowr
07-06-2014, 07:26 PM
anyone have an idea on what backspacing is needed for 18 x 275 wheel/tire combo up front?
J-440
07-07-2014, 05:04 AM
Jack your car up, take off the tire. Now get a plumb bob and take measurements and write them on the garage floor. Use a tape measure to get your spacing correct. Then take those dims to any tire/rim store and they'll hook you up. I did that and mine fit like a glove.
High Plains Mopars
07-07-2014, 07:26 AM
I'd suggest you visit a few more mopar oriented sites to work into some possible combinations of that. I believe it will fall somewhere between 5.5 and 6, but the offset of that back space is equally important. Try protouringmopar.com, moparts.com, or cuda-challenger.com
hogpowr
07-11-2014, 01:39 PM
thanks guys. ordered some hotchkis stuff for the front end. going to wait until winter to really get into the back half of the car. I hate having a perfectly good car tied up for the few nice months we have here in milwaukee. BTW. if anyone reading this is in milwaukee area. lets hook up. I don't know anyone in the area into old cars that drive hard, shift nicely turn and stop. (and actually use the cars for that purpose) most people around here that have old cars, couldn't imagine leaving in a cloud of smoke, stopping fast or turning their 40 year old car around much more than their driveway.
