View Full Version : Hard shift from 1st to 2nd HELP
BigVin
06-17-2014, 01:14 AM
I have a 96 4l60e behind 350 chevy with 373 rear and TCI 2nd gen controler. When it shifts from 1st to 2nd at a low speed it bangs into gear at higher speed it chirps the tires. Ive bled off 70% of the line pressure and dont want to bleed any more. I would like a softer shift at a slow speed. The trans shifts great except for that. Could it be a sensor or tune or both just looking for input from someone with experience with this setup
andrewb70
06-17-2014, 08:37 AM
What trans controller are you using? You should be able to tune that out.
BigVin
06-20-2014, 12:00 AM
heres an up date the tccvalve bore is worn. the fix is the sonnax tcc regulator valve and reamer. ream the bore install the valve.
