IMPALAMAN1
06-02-2014, 11:29 AM
im at a cross road... was talking with my chassis guy.. and he has a 2010+/- camaro rear cradle setup that he is willing to sell me. from rotor to rotor.
1968 impala
plans are for a high 600 hp 6.0 motor 4l80e trans. spirted driving with occational track days.
my current setup. has not even been driven on.
12 bolt series 1 carrier posi with 3:73 gears
4 bar
watts link. disc brakes
camaro setup
The good...... is obvious.
Factory big disc brakes.
Decent gears
I don’t have to worry about drive shaft angle
Off the shelf parts.
The bad
weight????
brackets/ alignment
Possible custom control arms
Possible custom axle shafts
frame rail cutting....
would be better suited for autocross
the good for the factory setup
already have the parts
85% completed on the chassis. need to mount shock brackets and final weld the watts link.
should work for both autocross/ drag pass
The bad if I keep the current setup........ I have a lot invested in the current setup with time and research/ not a whole lot of money but money none the less.
I would have to change the posi unit in the current rearend to a stronger one
Have to upgrade the rear brakes
Possible weak link in the drive train
So at min.
Im bigger brakes and a posi unit on the current setup.
I refuse to run pancaked rear wheels on an old car. so the shortening of the rear would be a must ( i have not compaired width yet)
1968 impala
4 bar
camaro setup
Decent gears
The bad
weight????
brackets/ alignment
So at min.
