thinkfastroth
06-01-2014, 11:36 AM
Hey guys,
We are listing this for a friend who has lost all interest in the project and is ready to do other things.
It is a 1969 Crate Camaro which was purchased through Classic Industries in 2008 along with nearly everything to make a functional car.
This is the body with the extended wheel tubs.
The intention was to have a 2 seat coupe, so a custom fiberglass toneau cover was created. The cover is on the body and can be completely removed and have a convertible top installed.
The gaping was pretty bad, so the doors, fenders, hood, decklid and body have had metal added to close the gaps.
The doors have had the handles and lock openings filled and smoothed.
An Electric Life reverse opening hood kit has been installed.
Detroit Quadralink Rear Suspension is installed
Chris Alston Subframe and suspension installed
Subframe connector is installed
The dash has been reworked for what was to be a custom built dash overlay.
All of the body has been filled and block sanded several times and shot with a sealer coat of DP90 epoxy primer.
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6459_zpsbed34801.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6461_zps2b2d0e2b.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6616_zps29971130.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6617_zps88dc7dd4.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6652_zps701df7e7.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6660_zps646d0650.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6662_zpsf4db2057.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/HPIM6902_zpsf5a30bed.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220237_zpsfa906a31.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220238_zps95d170bd.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220239_zps6f1d12ee.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220240_zpsa09864e6.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220241_zpsd7d3dfb4.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220243_zpsea0a649a.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220244_zpsb679e340.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220245_zps1e19bbbc.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/P4220246_zps19202b8f.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/20140601_120218_zpsrcwmj3en.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/20140601_120230_zpszyeppmjp.jpg.html)
https://static1.pt-content.com/images/noimg.gif (http://s1191.photobucket.com/user/MustangShooter/media/69%20Camaro%20for%20Sale/20140601_120253_zpszeafghn6.jpg.html)
This is a parts list that is in no specific order, they are listed as I have found them:
Chris Alston Camaro Power Rack Shaft and U-joint for Bolt in Sub Frame - 6188-PS
67-68 Camaro Speedometer Cable - KW870
Wilwood Rear Disk Pads - pair 150-8850K
69 Camaro Wiper Motor - no part number new
Keisler Hydraulic Clutch w/ Remote Reservoir
69-70 Camaro Door Latch Assembly RH - 8720401
69-70 Camaro Door Latch Assembly LH - 8720402
69 Camaro Brake and Clutch Pedals w/ Rubber Pads
67-69 Camaro Fan Shroud Bracket - 3938612
Mr. Gasket Pressure Plate Bolts - 910
Mr. Gasket Flywheel Bolts - 912
Urethane Body Mount Kit - unknown mfg
69 Camaro Headlamp Bezel LH - 396201
69 Camaro Headlamp Bezel RH - 396202
68-69 Camaro Wiper Transmission Arms - 4918754
69 Camaro Emergency Brake Pedal Assembly - K1107
69 Camaro Right Door - Aftermarket Replacement DII
69 Camaro Left Door - Aftermarket Replacement DII
69 Camaro Convertible Glass Kit - appears to be unopened
*67 Camaro Convertible Glass - removed from original car:
*Clear Driver Door and Wing Window
*Clear Passenger Door and Wing Window
*Clear Driver Rear Quarter Glass
*Clear Passenger Rear Quarter Glass
69 Camaro Master Body Bolt Kit - 69FB-S
Wilwood Rear Caliper - pair 120-6806
Wilwood Rear Park Brake Mount for Caliper - pair
Wilwood Front 4 Piston Caliper - pair
Air Ride Front Shockwave Air Spring w/ Shock - pair
67-69 Camaro Firewall Plastic Wire Gutter - 3864327
67-81 Camaro Brake/ Clutch Pedal Pad - pair K981
68-69 Camaro Door Jamb Vent Grill - pair K921
69 Camaro Front Bumper Corner Mount Kit - K533
67-69 Camaro Washer Jug - 3840083
66-74 Camaro Headlamp Mounting Bracket - K892
66-72 Camaro Washer Jug Mounting Bracket - 548935
69 Camaro Front Spoiler Bracket Kit - K910
69 Camaro STD/RS Paint Seal Kit - K927
69 Camaro STD Lens Gasket Kit - K726
69 Camaro Cowl Firewall Seal Kit - K930
69 Camaro Headlight Housing LH - CHP-65LH
69 Camaro Inner Fender Apron Set - K924
66-74 Headlamp Mounting Bucket - K893
67-69 Camaro Convertible Windshield Wiper Arm - K589
67-69 Camaro Quarter Window Attach Assembly LH - K845
69 Camaro Tail Light Lens RH - 5961568
69 Camaro Tail Light Lens LH - 5961567
69 Camaro Fuel Sending Unit w/ vent, 3/8" - 6428322
69 Camaro Kick Panel Insulation - no PN
67-69 Camaro Stainless Wiper Blades - G5675
67-68 Camaro Cowl Firewall Seal Kit - K929
67-68 Camaro RS Back Up Lens Gasket - K729
67-68 Camaro RS Paint Seal Supplement - K928
67-68 Camaro RS Back Up Housing Gasket - KW237
69 Camaro Park Lamp Assembly - pair 916911
67-69 Camaro Gas Tank Anti Squeak Insert Set - K915
69 Camaro Rear Bumper Bracket Set - K871
67-69 Camaro Window Verticals w/ Steel - K355
69 Camaro Park Lamp Lens Front - pair K658
67-69 Camaro Rear License Plate Lamp Assembly - 911576
67-69 Camaro Headlamp Dimmer Switch - 1238706
67-69 Camaro Quarter Window Molding - pair K1039
68-72 Camaro Rear License Plate Bracket - 334330
69 Camaro Headlight Housing RH - CHP-66RH
69 Camaro Rear Bumper Outer Bracket - 3937560
69 Camaro Inner Frame Bumper Bracket LH - 3945767
69 Camaro Inner Frame Bumper Bracket RH - 3945768
67-72 Camaro Carb to Accelerator Cable - 3998633
67-69 Camaro Quarter Window Attach Assembly - K846
69 Camaro Inner Ext Bumper Bracket LH - 3949621
67-69 Camaro Console to Floor Bracket - 3893889
69 Camaro Inner Ext Bumper Bracket RH - 3949622
67-69 Camaro Park Brake Cable Guide - 3892744
67-69 Camaro Stainless Coupe Wiper Blades - G5675
69 Camaro Convertible Rear Interior Trim Panel
69 Camaro Coupe Rear Interior Trim Panel
Electric Life Power Window Kit
67-69 Camaro Rear Frame Rail LH - 1068S
67-69 Camaro Rear Frame Rail RH - 1068R
69 Camaro Front Bumper - K36768
69 Camaro Rear Bumper - K36770
69 Camaro Upper Grill Reinforcement - 3949707
69 Camaro Convertible Front Lower RH=LH - pair 4467508 (unsure of placement or function)
69 Camaro Park Brake Assembly - K1107
Electric Life Door Actuator Kit
Electric Life Trunk Actuator Kit
69 Camaro Rear Spoiler - 3949798
70 Camaro Z/28 Low Rear Spoiler - 3974538
Bill Mitchel All Aluminum Motown 427 (never installed- run only by Bill Mitchel)
Keisler TK500 Transmission Assembly
Electric Life Reverse Open Hood Kit
Chris Alston 69 Camaro Subframe Assembly
Detroit Speed Quadralink Rear Suspension
Strange Rear Axle for Quadralink
Ford 9" 3.55 gear and Posi - new never run
Recaro Race Seats - pair
Ididit Steering Column
69 Camaro Convertible Top
There are probably be a few more parts that I have not listed, but will go with the project.
We will gladly take any other photos you need or answer questions, just let us know.
It will probably be better to contact us directly @ [email protected], we check e-mail throughout the day and will respond as quickly as possible.
This will be a package sale, the parts will not be broken up and sold individually.
Sold as is.
Package price is $45,000.00 for everything associated with this project.
It is located near Harper, TX.
Dan
[email protected]
Sold as is.
Dan
[email protected]
